Drives: FR-S Monogram
Help! FR-S Exhuast
I found a TRD Dual Tip exhaust and a Catless T1R front pipe for a good price.
Was wondering if this is a good set up or if it's going to give me codes for not having a Cat? And if it drones? Would I need to get a tune if I run the T1R Catless front pipe and TRD catback? Also any performance gains? Everything else is stock expect for a K&N drop in air filter |
hey you, yeah you <3
Drives: 2014 37J FR-S
TRD exhaust w/ TRD intake gains range 6-10hp. Toyota somewhere claimed 10-15hp. I felt no difference. Butt dyno.
You need a tune for best xp. If not, should be fine. Catless and codes? IDK.
Drives: UltraMFrS
removing any cats would most likely throw code CEL, will need tune
#4 | |
Drives: 2005 Toyota Camry
Catless front pipe without properly sized resonators WILL give you drone. -alex |
Not a troll
Dual tip TRD will not fit the stock bumper cut outs. You will either have to find a TRD bumper (good luck with that) or cut the stock openings. There are inserts you can buy if you go the surgical route.
Drives: frs
Or he can go to a muffler shop and redo the tailpipes
Sort of defeats the purpos of buying dual tops in the first place though.
Undisputed El Presidente
Drives: Zenki 37J ZN6
Custom T-tops or softop/hardtop combo?
#10 |
Tip not tops. Although you will never top my tip.
#11 |
But can I tip your top?
#13 |
DUAL tip not QUAD TIP... I am referring to the tips that are half circle (like a triangle) the tips will fit the current exhaust cut out
#14 |
Quad tips= 2 tips on each side
Dual tips = 1 tip on each side |
| Exhuast confusion | xsnapshot | Engine, Exhaust, Transmission | 10 | 06-30-2015 02:21 PM |
| FS: TRD exhuast | Obja | Engine, Exhaust, Bolt-Ons | 4 | 07-14-2014 11:14 AM |
| WTB Trd exhuast $500 | davebrus | Want-To-Buy Requests | 1 | 03-19-2014 09:36 PM |
| WTB: TRD exhuast tips | davebrus | Want-To-Buy Requests | 1 | 02-14-2014 01:49 AM |
| Exhuast Sizes | kurbkilla | Engine, Exhaust, Transmission | 10 | 01-17-2014 02:55 PM |
