Drives: 2016 frs
19x10 offset no camber?
I'm going to be on Eibach sport line springs. 1.4" drop all around and I wanted to run a 19x10 et 38?? in the rear and a 19x8.5 et 32 in the front. Will this fit? I don't want to run a mass amount of camber either. Anywhere in the -2-4 area ill be okay with. Is this too much? or should I consider doing a 19x9.5 for clearance. I got these numbers from a wheel guy up here he says it wouldn't be much camber but I want to ask the entire forums to get your opinions!
Power Ranger Elite
Drives: '13 WRB Sport-tech
You're going to need coilovers to get the spring/spring perch clearance to run that wheel/tire size... no way around it. Forget the eibach springs and buy any coilover kit. wider wheels will only make your spring clearance worse.
| The Following 2 Users Say Thank You to jimmillion For This Useful Post: | Leonardo (06-21-2016), tooslow4umayne (06-21-2016) |
#3 | |
Drives: 2016 frs
Dang. I want to go bags ultimately so im trying to stay away from the coilovers since their about $2000. I just want a moderately low car for now that I can just reduce wheel gap with. 19s look great but im scared itll rub. What if I want 19x9.5 on eibach sportline springs ?? |
Is there any particular reason you want to go that wide?
| The Following 4 Users Say Thank You to D_Thissen For This Useful Post: |
#5 | |
Power Ranger Elite
ST colivers and or BC superlows come to mind which are both under a thousand dollars. Installation wise, it's gonna cost you the same or even less then installing the springs since the procedure is the same for the shop. Plus you can sell the coilovers after and make back half the money.
| The Following User Says Thank You to jimmillion For This Useful Post: | tooslow4umayne (06-22-2016) |
Drives: '23 BRZ Limited
^Huh? Why would you pay a shop for that?
A jack, some jackstands, and a few basic hand tools and can swap suspensions in a few hours. Literally. |
Not a troll
| The Following User Says Thank You to Cole For This Useful Post: | tooslow4umayne (06-22-2016) |
#8 | |
Drives: 2005 Toyota Camry
-alex |
#9 | |
Sent from my Nexus 6P using Tapatalk
#11 | |
Country Boy 4 Life
You should read through all the different airbag threads to figure out the wheel specs... Here is a good place to start... http://www.ft86club.com/forums/showthread.php?t=77588 My advice: If you want airbags, don't buy wheels that hinder fitment for airbags in the future. Good luck! |
| The Following User Says Thank You to Leonardo For This Useful Post: | wparsons (06-22-2016) |
#12 |
Drives: 2016 frs
I just like the look of wide aggressive wheels. Ontop of that i was told by a shop that it would fit with no issues lowered 1 inch but i was a little skeptical lol but still wanted to bring it up to you guys
#13 | |
Drives: 2016 frs
Now correct me if I'm wrong. But i know that the wheel offset is a huge difference between bags and lets say springs for example. But Wouldn't i be able to run spacers just to make the Offset lower and still be able to run the same wheels when bags come around ? I mean i don't know I'm curious |
#14 | |
If you know you're going to need the lower offset eventually, just buy the right offset for the airbags and set the alignment with springs to not have huge poke.
| The Following 3 Users Say Thank You to wparsons For This Useful Post: |
| Vossen VFS-2 19x8.5 +45 / 19x10.0 +50 | Mark@S | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 12-04-2015 04:17 PM |
| FS: Rotiform SNA 19x10 et29 | hybridcmk | Wheels and Tires | 39 | 11-17-2013 05:08 PM |
| Rotiform ind 19x8.5 and 19x10 | baggedbrz | Wheels and Tires | 3 | 10-22-2013 06:35 PM |
| FS: Rotiform SNA 19x9, 19x10 | FRS GT | Wheels and Tires | 21 | 04-04-2013 12:10 AM |
| What offset is legal? What offset provides most benefit? | bdohazelnuts | Tracking / Autocross / HPDE / Drifting | 2 | 02-08-2013 02:32 PM |
