| DIY (Do-It-Yourself) Guides For all DIYs. |
Drives: FRS-ULTRA(lol)marine
Header Wrapping?
Hey everyone,
I'm in the process of thermo-wrapping my headers, and am coming across some difficulties... I've gotten one corner done well, but the second corner (same side) I am having some "bulging" issues with the wrap. It is almost like the wrap is partially wrapping around itself/catching on itself/stretched out too far/pulled too tight but from what I can tell I am using the same serpentine rotation as before. I am using 1in wrap on the runners to just beyond the first bend, and 2in wrap after up to the cat. I've already done the overpipe, and one corner, and didn't see this bunching up issue. I don't have any pictures of it, since I was too busy swearing at it and being frustrated (sorry!)... I will take some tomorrow, as I will likely still be having the same problem. |
Drives: 69 Firebird, 2015 BRZ
Pictures will help understand your problems ... What type of wrap are you using????
More soon, Ed |
Drives: 15 BRZ LTD, 05 FXT
Using water to wrap it wet helps the wrap be a bit more compliant.
The type of wrap you're using makes a big difference as BRZHarley mentioned.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
Using LEDAUT multi-purpose
(amazon link) I've been moistening the ends of the wrap to get it started. I'm on my way to work now, but I'll post pictures tonight. |
Thanks for the interest on this guys... I solved the issue by using a new roll of wrap. I am guessing that the material was too stretched out when I put the wrapped the first corner, but with a new roll of material it was a-ok. I think I can de-stress the weave enough to use the remainder of both rolls on the other side. Finished pics will be around in a week or so =D
Drives: Subaru BRZ
Next time, dip all the wrap in a bucket of water before starting. It'll prevent the fiber crap from getting all over you and all over the place in general. Also makes the wrap cooperate much much more.
Some people say this is a bad idea, blah blah. Once you start the car and let it idle, it all burns off. So... yeah. Enjoy the lower temps and more heat scavenging.
#7 | |
Drives: frs
But this will accelerate the rusting process?
Drives: Subaru BRZ
| Wrapping stainless header | wootwoot | Engine, Exhaust, Transmission | 36 | 12-16-2019 04:08 PM |
| Header/Exhaust Wrapping Question(s) | Strife26 | Engine, Exhaust, Transmission | 15 | 12-25-2015 07:11 PM |
| Car Wrapping in Northern NJ | Verbal21 | NY / NJ / CT / PA | 10 | 03-27-2014 06:58 AM |
| Vinyl Wrapping | Lawnik | DIY (Do-It-Yourself) Guides | 57 | 12-10-2013 11:23 PM |
| carbon Wrapping | Ryan86 | AFRICA | 26 | 04-27-2013 03:05 PM |
