Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > NY / NJ / CT / PA
NY / NJ / CT / PA NY, NJ, CT, PA
Old 06-19-2016, 07:51 PM   #1
stevesnj
stevesnj's Avatar
RomRaider/ECU Flash help
Anyone have experience with ROMraider or ECUFLash that can help me get this to work? I just want to make sure i am doing this right. I dunno if its because it's a 2016 but I can't seem to get it to show the ECU info to change parameters. I live in Camden County but wouldn't mind traveling to someone not too far.
Thanks!
My 2016 Build thread
Old 06-19-2016, 09:43 PM   #2
steve99
Thanks!
suggest you read the Tactrix link below
read out your stock rom.
save the file as a .bin
if its a 2016 manual its likely ZA1JF40C
open it with a hex editor and search for "ZA1J" you will then find your calid
Old 06-19-2016, 10:28 PM   #3
stevesnj
stevesnj's Avatar
I was able to save it as a bin but when I try to open it in RR it says ECU definitions not found. But I have the latest defs, I think.
My CALID is ZAJ1F00C
Old 06-19-2016, 11:01 PM   #4
steve99
post up the bin and ill have a look
did you point romraider to the definition file ?
Old 06-19-2016, 11:09 PM   #5
stevesnj
stevesnj's Avatar
Yep, the last one is 32bitbase and there is another from 2009 I tried both.
Here's the BIN
Old 06-19-2016, 11:29 PM   #6
steve99
Here's the BIN
OK its a ZA1JF00C rom :-)
note romraider and ecuflash defs are different and not interchangeble
need 32bitbase and ECUFLASH defs for ECUflash
and romraider defs for romraider
don't mix them up does not work.
also beware of the OFT calid changes post up the rom your going to flash and ill check it
Old 06-19-2016, 11:44 PM   #7
stevesnj
stevesnj's Avatar
So should I put both the 32bitbase and ecu defs in the BRZ folder in romdata folder?
Old 06-20-2016, 12:01 AM   #8
steve99
Put them in directories as per the Tactrix thread link below
remove any romraider defs from ecuflash directories
Old 06-20-2016, 07:55 AM   #9
stevesnj
stevesnj's Avatar
Put them in directories as per the Tactrix thread link below, remove any romraider defs from ecuflash directories
I know they are separated but I'll check.
Old 06-22-2016, 12:51 PM   #10
vgi
Drives: frs
@stevesnj if you've read the rom then EcuFlash is fine. You just need now a RR ecudef file. see this thread from RR http://www.romraider.com/forum/viewt...hilit=ZA1JF00C
You can put the file in any location, your desktop if you wish. Then open Ecu Definitions -> Ecu Definition Manager window, click Add and load the saved file, click Save.
Now you should be able to open your rom.
PM me if you need help, i'm maybe 20-30 mins from you
vgi is offline   Reply With Quote
Old 06-22-2016, 08:50 PM   #11
stevesnj
stevesnj's Avatar
Awesome yes! I'd appreciate the help. where u at in NJ?
RomRaider itsjustdavep Software Tuning 34 03-18-2017 03:48 AM
Tuning for CAI w/RomRaider tskaohu Software Tuning 3 12-30-2015 07:16 PM
Romraider Down? RustySocket Software Tuning 7 10-02-2015 09:28 AM
dbw romraider mod RaineyStar Software Tuning 1 06-05-2015 11:53 AM
need some help with romraider logger toyotaAlex Software Tuning 2 07-06-2014 07:07 PM
