Old 06-17-2016, 01:40 PM   #1
mengmoua
Drives: 2016 Raven Fr-s
Installing OEM Suspension Help
I'm trying to install the 2 rear suspension. To take out the strut and spring we have to take out several other bolts/nuts. After switching the strut and spring, I'm having a hard time lining the holes back up to the lower control arm. No matter which bolt insert first, the last hole doesn't line up. It's always end up about 1 inch too far out (Looking from the rear, the passenger side lower control arm is 1 inch to far left). Any ideas?
Solved.
mengmoua is offline   Reply With Quote
Old 06-17-2016, 01:41 PM   #2
wparsons
wparsons's Avatar
Is the LCA still connected to both the subframe and the knuckle? If so, you might have to put a spring compressor on the spring to compress it a bit. You could also remove the bolt holding the LCA to the knuckle, but then you'll have to wrestle it back in later on.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
mengmoua (06-17-2016)
Old 06-17-2016, 02:09 PM   #3
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Release the ebrake
Or if thats not it take pictures cause Im not exactly sure where it isnt lineing up (strut, knuckle, etc)
Old 06-17-2016, 03:27 PM   #4
Nickosport
Drives: 2015 WRB BRZ Premium
When i did my lowering springs I had to have a buddy pull down on the RLCA to get the bottom bolt to line up to bolt up the damper. It took a fair bit of muscle. Some say to disconnect the sway bar to make it easier. Is that the one you are talking about?
2015 WRB BRZ - Nameless - Raceseng - Eibach - Whiteline - Cusco - Perrin
Nickosport is offline   Reply With Quote
Suspension Super Sale ISC Suspension | KW | Tein | Cusco and More OCRaceShop.com Brakes, Suspension, Chassis 14 08-26-2015 10:43 AM
Squeaking / Creaking rear suspension with low ride height? Suspension pros welcome! mothespaceman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 08-14-2015 05:06 PM
Installing an Airlift Performance suspension on a BRZ Mach V Dan Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 07-29-2015 11:20 PM
need help installing this chenshuo Cosmetic Modification (Interior/Exterior/Lighting) 6 07-14-2013 01:17 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
