Old 06-16-2016, 05:00 PM   #1
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
KW Coilovers: How much does one turn equal in ride height?
I currently have RCE Tarmac 2's which have the same body design as the KW V3's. Anybody know how much 1 turn of the collar equals in actual ride height? I'm sitting at 25.25" but would like to drop my ride height 1/4" before my next alignment.
It's currently even all around, so I was hoping to avoid having to do a bunch of measurements to get it right again this time. Like just a few turns on each corner and done.
smg1138 is offline   Reply With Quote
Old 06-16-2016, 05:22 PM   #2
strat61caster
strat61caster's Avatar
1 turn should be ~0.08" per my buddies experience.
This is true for the front but the rears have a ~0.77 motion ratio so 1 turn there is 0.06"
Rough guess: a little more than 3 turns in the front, a touch more than 4 turns in the rear.
Edit: Whether you go with 3 or 3.5 or 3.25 is up to you, if you're dead set on a 25" height try 3.25 turns front, 4.25 turns rear.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
bmacfrs (05-16-2020), smg1138 (06-16-2016)
Old 06-16-2016, 05:22 PM   #3
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Most coilovers have the same thread on the shock body. What you have on your car should be virtually the same as what is on the V3.
In general, if you are changing ride height by lower bracket, you can measure it easily by turning the bracket to the height change desired, then locking it.
-alex
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
smg1138 (06-17-2016), strat61caster (06-16-2016)
Old 06-16-2016, 09:22 PM   #4
smg1138
smg1138's Avatar
This is exactly what I was looking for. Thanks!
Old 06-16-2016, 11:19 PM   #5
strat61caster
Mav is correct too, can measure the spring perch height to confirm before setting the car on the ground again.
ineedyourdiddly
Old 06-18-2016, 05:07 PM   #6
smg1138
smg1138's Avatar
I lowered my T2's 3 turns last night and it measures 25" on all corners now. That's with a full tank and all the trunk junk.
Stock Ride Height? JimmyMac Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 03-10-2015 11:46 AM
Ride height issues with coilovers wootwoot Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 12-27-2014 11:09 AM
BRZ vs 86 stock ride height Moe AFRICA 2 11-21-2013 08:35 AM
Stock ride height or lower? StevenDavisPhoto Suspension | Chassis | Brakes -- Sponsored by 949 Racing 156 01-31-2012 10:58 AM
Lower ride height in NYC? blur NY / NJ / CT / PA 9 01-19-2012 06:31 PM
