Old 06-10-2016, 07:42 PM   #1
zenex
Drives: 2014 Boosted Subaru BRZ Limited
Is r154 swap possible?
Possible to swap r154 trans to the fa20? I see mount kits but there always for 2jz swapped brzs
Sent from my SM-N920V using Tapatalk
zenex is offline   Reply With Quote
Old 06-11-2016, 12:16 AM   #2
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
The very short answer is "sure, with enough money you can swap anything"
The less facetious answer is no. I assume you are asking if you can buy off-the-shelf parts to do it. That answer is no.
The only current off-the-shelf transmission swap (not counting proprietary sequential units) for the FA20 is the V160 / 161 kit from Full Blown Motorsports. It's expensive.
Can the R154 be done? Yes, but you're on your own.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Rod Swap protpibe Engine, Exhaust, Transmission 6 10-21-2015 11:38 PM
2JZ swap? jordydiaz Engine Swaps 44 05-21-2015 10:19 PM
Looking for an STi Swap Doug@WGP NY / NJ / CT / PA 31 11-27-2012 12:54 AM
Key Fob Swap joergasm BRZ First-Gen (2012+) — General Topics 1 10-02-2012 11:40 PM
