Kurenai Samurai
Drives: Red and manual
warning about Walnut Creek Toyota
I recently had my transmission replaced under warranty with these guys and when I got my car back they had cross threaded my shifter knob (minor obviously), they installed the shifter plate backwards so I needed to lift the shift lock collar to even get into 1st gear...then when I finally got it back there was a rattle sound coming from it. I told them to check it out but they denied it because they blamed the rattle on my after market exhaust. So I took my car to a local car shop that we deliver to (I work at a dealership also)for a second opinion, they discovered a sheared stud and a crack in my block due to improper installation. So needless to say I will be going back there and demanding they fix the car and if they try to deny my then I will be pressing charges.
Do not go to Walnut Creek Toyota in CA east bay. Crooks. |
post this in your local section too if you haven't already
hey you, yeah you <3
Drives: 2014 37J FR-S
Yeah. I took my car in for the tob as it was closest dealer. They said all is well. Took it again. They were annoyed by it and had horrid customer service. I ignored my issue for a couple of weeks, then took to closer dealer where I live. They found bad tob and placed new one. WC Toyota is known for selling crashed vehicles as clean title and doing crook jobs as you put it. I reported their bad service and refusal service to Scion in LA. Dont know if anything will/did happen but I encourage you to do the same. Voice your issue.
Call SCION first. Explain what happened, they are very good and helpful usually and will start a case for you. Go up the chain of command.
http://toyota.custhelp.com/app/answe...ntact-scion%3F
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
Mentat
Drives: 2013 Scion FRS 6MT
They usually let the 1st year guys do the warranty work.
Rest assured I Will NOT be using their services!!!!!!!!!
| WARNING: Cambridge Toyota BRUTAL SERVICE | tiz22 | CANADA | 54 | 10-30-2014 08:31 AM |
| Walnut Creek, CA Lounge Suggestions! | 1SIKFRS | Off-Topic Lounge [WARNING: NO POLITICS] | 0 | 11-23-2013 07:21 PM |
| Stock Wheels and Tires (SoCal, Walnut) | davidshu0327 | Wheels and Tires | 1 | 03-02-2013 06:13 AM |
| WARNING! TOYOTA (TMCA) is watching! Be careful what you post online! | Psyco | AUSTRALIA | 127 | 10-24-2012 02:45 AM |
| Toyota 86 Subaru BRZ Hyper Magazine meet in Japan (warning pic heavy (56k beware)) | tecnica tech | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 59 | 04-18-2012 01:01 PM |
