Old 06-04-2016, 07:11 PM   #1
SyntrexFRS
SyntrexFRS's Avatar
Drives: 2013 Scion FRS Grey
Question about using OFT while under warranty
Hey guys,
Exactly as the title states. I want to get the open flash tablet and im aware that I can flash back to my original rom if I need to go to the dealership but I am still very hesitent to get this. I want it very bad and I its worth the money but its not worth voiding my warranty if it does. So have any of you used this while still under warranty and if so have you come across any issues?
Thanks,
Syntrex
SyntrexFRS is offline   Reply With Quote
Old 06-04-2016, 08:36 PM   #2
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
Originally Posted by SyntrexFRS View Post
Hey guys,
Thanks,
Syntrex
You can't have your warranty "voided" with any mod. The dealership has the capability to not pay for warranty work on specific parts if they suspect the problem was caused by your mod or abuse. For example they could refuse to cover the ECU warranty if it failed and they found that you had bricked it. However they would not be able to deny a warranty claim later on if your paint started to fall off in big flakes.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
The Following User Says Thank You to Apoc For This Useful Post:
SyntrexFRS (06-05-2016)
Old 06-04-2016, 10:03 PM   #3
steve99
Hey guys,
Thanks,
Syntrex
The only 100% way to have the least possible waranttee issues is to leave car 100% stock.
With the OFT you have the abbility to flash back a 100% stock rom byte for byte back to ecu..
The dealer will see the same CVN or check sum ans same calibration id as stock if this is done. Extremly unlikely they would look further or be able to detect anything at dealer level.
If you had other mods such as catless header or intake these are easily spotted by dealers.
A tune is far more difficult to detect and if returned to stock virtually impossible at dealer level. Eeven if the ecu was sent for anaysis at higher levels all they may find is that it was reflashed but any evidence od what was flashed would be gone as each time a new tune is flashed the old one is completly erased from ecu.
Other tune systems such as ecutek leave some embedded licience info in the ecu code and this can be detected unless you overwrite this using an opensource tune system.
Basicly tunes are not easily seen,and if using oft and you wrote back a completly stock rom to car for service (and had no other visible hardware mods) you would be extremly unlikely to have any issues or be detected.
Old 06-05-2016, 01:15 PM   #4
SyntrexFRS
SyntrexFRS's Avatar
Thanks Steve for the very informative response and quick at that. What you said has kinda put me at ease and I think I may pick one up because the pros are really great in my eyes and from what you and everyone else on the forum is saying I shouldnt have any detection issues and the bottom line is if i use the stage1-4 maps that is provided with the OFT the chances of something breaking is not likely at all and if something was to break it would most likely not be caused by the tune but by something else (that was something I saw Shiv say on another thread)
Old 06-06-2016, 12:33 AM   #5
Ashikabi
Ashikabi's Avatar
Fyi, even if it's 110% not because of the tune, flash it back to stock BEFORE going to the dealer. They will try to blame any and all drive train issues on the tune.
The Following 2 Users Say Thank You to Ashikabi For This Useful Post:
chaoskaze (06-06-2016), SyntrexFRS (06-06-2016)
Old 06-06-2016, 12:44 PM   #6
SyntrexFRS
SyntrexFRS's Avatar
Yea i dont ever plan on going to the dealer with the tune applied i was more or less concerned on whether they would be able to detect that it previously was applied and flashed back to the original
Brake Warranty Question... Uplink Scion FR-S / Toyota 86 GT86 General Forum 43 05-08-2015 12:53 PM
Warranty Question WazzuGrad Northwest 1 01-16-2015 09:06 PM
Scion Warranty Question JJGraphiX Issues | Warranty | Recalls / TSB 5 09-20-2014 03:01 AM
TRD Warranty Question soontobrz Issues | Warranty | Recalls / TSB 1 09-08-2013 08:56 PM
Subaru Warranty Question Sovran BRZ First-Gen (2012+) — General Topics 3 06-04-2012 12:59 PM
