Old 05-31-2016, 10:18 AM   #1
UnluckySkmr
Drives: 2013 SWP BRZ Limited
Clutch issue after sitting over night
Been dealing with this for about a month now. When I start my car in the morning I let it warm up no matter if its cold or warm outside. When I leave for work sometimes my clutch feels like it is slipping. I let the clutch out and give it gas and it feels like is about to stall. Shakes and bucks. This happens in 1st gear only. If I start in 2nd gear no issues. After I drive about a 2-3 miles it clears up and drives normal for the rest of the day. I am the second owner and when I bought the car it had 7k miles, has 24k miles now. I have been driving manuals for about 10 years and I have never experienced this on a car with low miles. Checked through the forums and google and cant find anything that says this is an issue for our cars. I could take it to the dealership but odds are that the car wont reproduce the issue so I will be without a car until they figure it out. Any help would be great.
UnluckySkmr is offline   Reply With Quote
Old 05-31-2016, 05:10 PM   #2
humfrz
The first thing I would try is the old "see if the clutch disk is wore out" test.
Warm up the engine, set the emergency brake, put it in 2nd gear, rev to about 3,000 rpms, let the clutch our slowly. If that kills the engine, there is a good chance the clutch disk still has some life left in it.
It could be the notorious throw out bearing acting up.
It could be the pressure plate is warped (or otherwise messed up) (unlikely).
Anyway, that is not "normal" for a clutch to do that (with an experienced driver).
If it's still under warranty, I'd suggest you park it overnight at the dealership then ask a tech to fire it up in the morning, to see if it can be duplicated.
humfrz
Old 05-31-2016, 06:54 PM   #3
ls1ac
ls1ac's Avatar
seems like two conflicting things
a warn / slipping clutch will let the engine rev and slowly start the car moving and will seem smooth.
a grabbing and bucking engagement often comes from a rapid engagement at too low an rpm. starting in 2nd will require more slipping of the clutch and will seem to start smoothly.
side note: clutches and brakes often work better with a little heat; also a competition clutch is more difficult to engage smoothly it likes to be in or out.
perhaps a little more info would help problem solve.
Old 05-31-2016, 08:00 PM   #4
UnluckySkmr
Yes your right it's more of a grabbing issue. Felt it again pulling out of the parking space at work. I can feel it through the clutch pedal trying to grab. Even tried more rpms and letting off the clutch slower after reading your reply and it gave me the same result.
Old 05-31-2016, 09:13 PM   #5
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
It really sounds like the clutch is going out.
Old 06-01-2016, 07:10 AM   #6
ls1ac
ls1ac's Avatar
Have you been doing hard starts or burn out s or riding the clutch on hills
Fly wheel or pressure Plat e with hot spots will act like that and get better with heat for a short time
Old 06-01-2016, 07:17 AM   #7
UnluckySkmr
Have not done any of those. I do use the clutch to hold the car on small inclines. It goes away completely after driving a few miles.
Old 06-01-2016, 07:37 AM   #8
ls1ac
ls1ac's Avatar
You can try using the hand brake on hills
If nothing is warped it might clear up with time
Once a hot spot has developed it will be the first place to heat up when the clutch is ridden on a hill
clutch Engagement Issue? Bu-Tang Issues | Warranty | Recalls / TSB 68 02-19-2017 02:03 PM
Clutch engagement issue. Possible clutch cylinders upgrade? wu_dot_com Engine, Exhaust, Transmission 42 04-05-2016 12:11 PM
Clutch issue. Need help with flywheel. MoreBoost Engine, Exhaust, Transmission 2 01-26-2016 11:01 PM
clutch issue yurgirlishot Issues | Warranty | Recalls / TSB 14 11-15-2013 04:20 PM
Clutch / Diff / Gearbox issue? doggy Issues | Warranty | Recalls / TSB 5 10-03-2012 10:47 AM
