Old 05-30-2016, 06:53 PM   #1
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
Eneos Gear Oil
http://www.eneos.us/products/eneos-gear-oil/
ENEOS Gear Oil GL-5 75W90
Just wondering, can i use this for my transmission? I want to change the transmission fluid since my gears are not smooth.
I see it's the same as Motul 300 in regards to being 75W90.
Reason for wanting to use this is because I already use Sustina 0w20 oil from them and like the product.
Thanks
2018 Subaru WRX STI ~ The Weekend Car ~
2015 Toyota 86 ~ The Sold Car ~ Build Journal
OFT Stage 1 Tune Review
Mr.Impreza is offline   Reply With Quote
Old 05-30-2016, 09:13 PM   #2
humfrz
Well, according to my manual, the manufacture calls for a GL-3 oil in the MT......not, GL-5.
This is what Wiki tells me:
EP additives which contain phosphorus/sulfur compounds are corrosive to yellow metals such as the copper and/or brass used in bushings and synchronizers; the GL1 class of gear oils does not contain any EP additives and thus finds use in applications which contain parts made of yellow metals.
"GL-5 is not necessarily backward-compatible in synchro-mesh transmissions which are designed for a GL-4 oil: GL-5 has a lower coefficient of friction due to the higher concentration of EP additives over GL-4, and thus synchros can not engage as effectively. Also, transmissions which explicitly call for GL-4 oil may have been designed around this lower concentration of EP additives and thus may contain yellow metal parts which GL-5 will corrode".
Your call .....
humfrz
Motor Oil, Gear Oil, Oil Filters, Company 23, Motul, Redline, Eneos, SubaruOEM @OAKOS OAKOS Automotive Mechanical Maintenance and Tools 34 02-26-2016 10:26 AM
ENEOS/ENEOS Sustina 0W-20 used oil analysis: was:ENEOS 0W-20 versus factory synthetic mav1178 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 80 01-06-2016 03:36 PM
Eneos 75w-90 Oil for MT Numb Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 25 12-03-2015 06:05 AM
ENEOS SUSTINA 0W20 MOTUL GEAR 300 DAN_BRZ Canada Classifieds 4 05-12-2014 07:03 PM
eneos en-gear 75w90 BadCompany235 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 01-03-2013 05:48 PM
