Old 01-03-2013, 10:32 AM   #1
BadCompany235
#TrackAddicts
BadCompany235's Avatar
Drives: The Dipped Car
eneos en-gear 75w90
gl5 but a good price and looks like it meets the requirements. any thoughts. not a fluids expert here.
btw the motul i see everyone using is also gl5.
Racecomp Engineering / FT-86 Speedfactory / Essex / Counterspace Garage / Topspeed Motorsports / Forged Performance
Chadbee Photography / Passion Moves Photography
BadCompany235 is offline   Reply With Quote
Old 01-03-2013, 03:02 PM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Motul is GL5 AND GL4
Anything that is ONLY GL5, can only be used on the Diff, but NOT in the tranny. Anything for the tranny has to be GL3 or GL4 or GL5 and GL4.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
AZP Installs (01-03-2013)
Old 01-03-2013, 03:08 PM   #3
gmookher
in the tranny? no. what about cST guys? additive packs? gl4? see my pentosin thread for tranny oil guidance, on pg 11 there are others if you prefer other than pentosin
we all have our reasons for choosing our fluids...
as for the eneos en-gear in the rear diff, why not? prolly good stuff
Typical Properties
SAE viscosity grade 75W-90
Density (20°C), g/cm3 0.8834
Flash point (COC), °C 204
Kinematic viscosity (40°C), mm2/s 79.9
(100°C), mm2/s 14.6
Viscosity index 192
Pour point, °C –42.0
gmookher is offline   Reply With Quote
Old 01-03-2013, 05:48 PM   #4
getbent
Drives: 2013 FR-S Blue MT
I would try to stay with pure GL-4 fluid. GL-5 fluid has extreme-pressure additives which are designed for differentials and not transmissions. A GL-5 fluid can meet GL-4 specs for not corroding soft metals, but it still has additives that are not necessary or preferred in a manual transmission.
That ENEOS GL-5 should work just fine for the rear diff, although probably any GL-5 would.
2013 Scion FR-S | 6MT | UltraMarine
getbent is offline   Reply With Quote
The Following User Says Thank You to getbent For This Useful Post:
Sportsguy83 (01-03-2013)
Eneos 0w20 Hayashi Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 154 10-27-2014 05:04 PM
eneos sustina 20valvewynn83 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 01-04-2013 09:43 PM
Good price for Eneos 0w-20? Gregory Gawaran Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 07-26-2012 01:38 PM
Free Shipping on ENEOS Oil KronosPerformance Engine, Exhaust, Bolt-Ons 12 06-22-2012 06:17 PM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 01:21 PM
