Old 05-28-2016, 06:37 PM   #1
jackblack21
Drives: red scion frs
Advice on this HKS kit Please!
Am looking to get a supercharger for my 2013 FRS. Came across this kit with pre programed software.
http://www.kijiji.ca/v-engines-and-e...ationFlag=true
Was wondering if a stock car needs anything other than that kit to run safely?
Does anyone have any idea how well the out of the box Tune will work?
I need my car for daily use. I only want about 50-70hp and more torque. I don't plan to track the car (well maybe a bit but not beat on it) but do want it to pull from time to time.
Any advice would be welcome!
jackblack21 is offline   Reply With Quote
Old 05-29-2016, 03:20 PM   #2
Ashikabi
Ashikabi's Avatar
I'm not 100% familiar with FI but that kit should have everything you need(otherwise why make a kit). Of course there are other mods you could do to"support" it like an oil cooler but honestly if it's a DD you don't really need anything else. Have you considered e85 and headers instead? Will cost much less but won't be as big a power bump. Something to think about
Old 05-29-2016, 03:44 PM   #3
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
I wish it was law to have e85 at every station. I have 2 within 20min drive, so DD e85 isn't an option.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 05-29-2016, 04:20 PM   #4
Ashikabi
Ashikabi's Avatar
Then SC is probably the next best option. Should be fine with just that kit. I don't know anything about the HKS tuning option though. Might be better with Ecutek or OFT for future tunability. Dunno
Old 05-31-2016, 03:11 PM   #5
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
Just wondering also, the tune that comes with the HKS Ver.3 Kit, is that for the stock header? Or aftermarket header?
Or it doesn't matter?
Just wondering cause on the website it just says 91 tune.
2018 Subaru WRX STI ~ The Weekend Car ~
2015 Toyota 86 ~ The Sold Car ~ Build Journal
OFT Stage 1 Tune Review
Mr.Impreza is offline   Reply With Quote
Old 05-31-2016, 03:13 PM   #6
Ashikabi
Ashikabi's Avatar
It will matter. There is a thread on here for/by the HKS rep, I'd find it and ask him. I think his name is Tony or Torry
The Following User Says Thank You to Ashikabi For This Useful Post:
Mr.Impreza (05-31-2016)
Old 05-31-2016, 05:12 PM   #7
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
Found it, thanks man!
The calibrations supplied in the Flash Editor (and the dyno results) were generated using the required HKS Spark Plugs, HKS Stainless Exhaust Manifold, HKS Stainless Center Pipe, and HKS Hi-Power Spec-L exhaust. I'm confident a comparable header/manifold will still work with the pre-loaded calibrations however, the degree of difference in performance vs. the HKS manifold will be the degree of difference in driveability and output. Of course you can always have one of our Pro-Dealers tweak or create a custom cal. for you.
Old 05-31-2016, 05:29 PM   #8
Ashikabi
Ashikabi's Avatar
Np. When I got my HKS mid pipe and new over pipe Delicious didn't think the tune needed changed so I'll bet the headers make the biggest difference. Keep in mind they probably tuned on their equal length pipes which make better power than unequal
Old 06-01-2016, 06:10 AM   #9
Apex-Apex
Apex-Apex's Avatar
If you're going to use the OTS HKS e85 tune, you'll also need to have their high boost pulley and injector set.
Varis 2JZ Build Thread
IG: @apexapexapex
Apex-Apex is offline   Reply With Quote
Old 06-01-2016, 08:30 AM   #10
Torry@HKSUSA
Torry@HKSUSA's Avatar
Drives: HKS
The HKS tune is a simple ECU flash. It takes all of about 2 minutes to do. You can also flash back to stock at any time with ease.
The V3 supercharger kit comes with the Flash Editor preloaded with two tunes - 91 octane and E85. The E85 requires you to also have the upgraded HKS supercharger pulley as well as upgraded injectors.
A 93 octane tune is also available but you must first connect your flash editor with the 91 tune then send it to us so we can add the 93 tune as an option.
Our 91 and 93 tunes were created using HKS equal length header, midpipe, and catback. These are not required for the tune, but you will simply make less power with using the stock exhaust components. Our testing put down 244 whp on 93 octane on a Mustang dyno with the full HKS exhaust. On the stock exhaust, expect about 20 hp less, give or take.
If you are looking for a custom tune, any HKS Pro Dealer will be add a custom tune to the Flash Editor. There is a selection for "Power Writer" which is where we add the 93 tune if you send it into us. Otherwise an HKS Pro Dealer can do a custom tune in that slot.
Let me know if you have any other questions.
Torry@HKSUSA is offline   Reply With Quote
The Following User Says Thank You to Torry@HKSUSA For This Useful Post:
Mr.Impreza (06-01-2016)
Old 06-01-2016, 08:48 AM   #11
Torry@HKSUSA
Drives: HKS
Also, just to be clear so there is no confusion:
HKS states in the manual that an upgraded cat-back and header are required. These are required to create the power that HKS states the kit will make, and that is what the tune was created for. However, a more restrictive exhaust (such as stock) should not affect the required tune, just the power output.
Old 06-01-2016, 09:59 AM   #12
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
This is all great to know! That was actually going to be my next question today, if you could still run this setup with stock components. Thanks Torry!
Really need to start saving up for this
Old 06-04-2016, 10:40 AM   #13
sroby
Drives: 2015 Firestorm 08/05/15
Torry any updates for us with 2015 FRS,s ecm flashes. I am ready to purchase and am currently running an oft also here in Atlanta we have to deal with the emission crap. Can you point me in the right direction of any shops in our area that can't tweak the programs to pass the emissions. I am planning on keeping the stock header and cat. I already have a cat back. Thanks for any insight. Best regards Steve
sroby is offline   Reply With Quote
Old 06-04-2016, 11:18 AM   #14
Torry@HKSUSA
Drives: HKS
HKS engineers were here a week ago and finished development for 2015 and 2016 models. They now have to update the software for the current inventory on-hand. We are expecting to receive the production version of the updated software next week sometime and will be making the official announcement probably the following week. So it's really close to being done.
For emissions in Atlanta, you have nothing to worry about. The supercharger kit will not through a check engine light and you are keeping your cat. That's really all they look for. I'm originally from Atlanta so I'm familiar with their emissions tests and they aren't anything to worry about, unlike CA's CARB certificates.
Any advice !? rawrmatty Scion FR-S / Toyota 86 GT86 General Forum 38 07-22-2014 01:29 PM
Advice JG Scion FR-S / Toyota 86 GT86 General Forum 7 06-30-2014 08:20 AM
Need advice!! Black_Pearl Scion FR-S / Toyota 86 GT86 General Forum 5 12-10-2013 12:14 PM
Some advice zoomzoomers Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 04-22-2013 05:16 PM
Need advice FRSMAK86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 08-06-2012 05:39 PM
