Old 05-28-2016, 10:29 AM   #1
shellslinger
Drives: Whiteout FRS
Front Driverside Wheel Clunk
Hey guys,
Wondering if you guys could help me locate this issue. From a stand still if I turn the steering right or left I get this clunk from the front Driverside wheel. I am currently running Tein Flex Z and 22mm Progess front sway bar. It didn't make this noise before, I've had these parts installed on for more or a less about a year.
Should I check the end links?
Thanks all!
shellslinger is offline   Reply With Quote
Old 05-28-2016, 10:36 AM   #2
Jack up that corner, grab the wheel and start pulling and pushing. See if you can spot anything. End links be a good place to start though.
Old 05-28-2016, 10:46 AM   #3
Drakiv
Project Shadow
Drakiv's Avatar
Drives: 2015 BRZ Limited 6MT
Yeah I would definitely do what Tcoat said and check your endlinks, sounds like if you got a stiffer swaybar they may have given up or started to give up.
FBM Stage 2 Turbo Project Shadow Build
614whp/421tq on E85
Instagram: Drakiv
Drakiv is offline   Reply With Quote
Old 05-28-2016, 10:58 AM   #4
shellslinger
Thanks fellas! Will do and report back
Old 05-28-2016, 10:07 PM   #5
shellslinger
So I took off the wheel and checked the end link and it looked fine. But when I looked under the hood, it looks like my bushing for my front sway bar is bad.
Here's a picture:
Front right clunk, tie rod scrape marks. EDIT: FIXED! :D BDotG Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 04-11-2016 09:28 PM
stock front drivers side suspension clunk. dkstylezz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 10-24-2015 01:19 PM
FS: Driverside weatherstrip frslee Exterior Parts (Aero, Lighting, Etc.) 2 05-05-2015 03:38 PM
End link jarring/clunk (front) tr3o Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 06-09-2014 12:32 AM
wtb whiteout driverside FRONT FENDER werunbklynn Want-To-Buy Requests 0 05-16-2014 09:38 PM
