Northern California NorCal
Old 05-26-2016, 09:58 PM   #1
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Best shifter
I have a stock shifter with a TRD short shift kit. It came loose today and I nursed it to the dealer in 3rd gear. They fixed it, but it doesn't seem that great now. What is the best shifter? I'm looking for something that looks stock and uses stock rev lockout and knob.
Old 05-26-2016, 10:01 PM   #2
sdemo
sdemo's Avatar
Drives: '13 SWP ZC6 R
Stock.
Everybody seems to have a hardon for MTEC springs and uprated shifter bushings as well.
sdemo is offline   Reply With Quote
Old 05-26-2016, 10:43 PM   #3
Sapphireho
Famous Potatoes
Sapphireho's Avatar
So your opinion is the stock one by itself is the best? I'm for stock look but function is #1. I drive very fast in the hills.
Old 05-26-2016, 10:52 PM   #4
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
What do you mean it "came loose"?
If you're talking about the TRD quickshifter (not to be confused with the TRD Japan shortshifter), there's a part in the install that requires blue loctite application - I'm wondering if that was missed, because I've had mine for about a year and a half, and I've never had issues.
daiheadjai is offline   Reply With Quote
Old 05-26-2016, 11:20 PM   #5
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Yes,trd quick shifter that extends the bottom, sold at USA Toyota dealers. I was thinking the same thing about the loctite. The dealer installed it for me. Dealer retightened it today. I have no doubt it will come loose again. Suddenly I couldn't put it in 1st or 2nd and everything was slop.
daiheadjai (05-27-2016)
Old 05-26-2016, 11:34 PM   #6
TM
TM's Avatar
Drives: DGM BRZ 6MT
That seems to be a common problem with the TRD short shifter. Mine came loose after a couple of months. I stripped out the previous loctite, reapplied it, and retightened. It's been good for over two years now.
TM is offline   Reply With Quote
Old 05-27-2016, 04:08 AM   #7
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Aki's custom shifter
Sypher (05-27-2016)
Old 05-27-2016, 01:18 PM   #8
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
I am using blox.
FR-Sky is offline   Reply With Quote
Old 05-27-2016, 02:25 PM   #9
daiheadjai
daiheadjai's Avatar
Gotta use the loctite... I didn't even use all that much, but it's held up (1.5yrs including one trackday).
I've also got the MTEC springs, but can't really comment on how necessary that is (never tried the TRD without them). A weighted shift knob (I have a 1lb stainless) also smooths the motion as well (while reducing the rattle that the stock knob often has).
Old 05-27-2016, 02:35 PM   #10
ZionsWrath
Thanks
ZionsWrath's Avatar
Stock shift knob is OK but I have been thinking to get a weighted one. Or maybe I should get gloves. I don't like how the shift pattern sticker sticks to my sweaty hand. and it also feels loose.
Old 05-27-2016, 04:57 PM   #11
PMok
Codename: Stitch
PMok's Avatar
just an FYI, the stock shift knob weighs 198g which is nearly half a pound... so it's got a surprisingly decent amount of weight/heft to it already. If you want a heavier one there are definitely some options though. FWIW I had an aftermarket stainless steel knob but ended up going back to stock because I liked the feel of it better.
Old 05-27-2016, 05:26 PM   #12
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
The stock shifter assembly is great already. A short shift kit is not only unnecessary for this car, but is irrelevant to however fast you drive in the hills. This is more a convenience and cool factor thing, and isn't anymore necessary to drive "fast" as are leather seats... not that it can't help
Toyarzee is offline   Reply With Quote
The Following User Says Thank You to Toyarzee For This Useful Post:
Cole (05-28-2016)
Old 05-27-2016, 07:23 PM   #13
Sapphireho
Famous Potatoes
Sapphireho's Avatar
The driving fast was more a reference for the need for smooth exact shifting, not stroke. I've had good shifters and bad in my track cars in the past, mostly 911s with clunky 915 tyrannys. I have plenty of sports car driving experience and my $.02 is a good short shifter makes it more convenient. I have also had short shift kits that make shifting worse. I'm the last guy into something because it is "cool". I'm about performance.
Old 05-27-2016, 07:28 PM   #14
Toyarzee
Shibby!
Toyarzee's Avatar
Definitely +1 sometimes making it worse lol. I hear ya then
Manual MT Shifter Boot Swap Onto Automatic AT Shifter Assembly? soulstice Cosmetic Modification (Interior/Exterior/Lighting) 52 01-24-2016 08:20 PM
Shifter springs/bushings/shifter performance Darnold Engine, Exhaust, Transmission 10 10-22-2014 11:49 PM
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 01:41 AM
TRD Short Shifter Quick Shifter Scion FRS hirollaz Transmission and Driveline 3 04-15-2014 01:24 AM
Shifter TSB 03-71-13 v. Perrin Rear Shifter Bushing swansons Issues | Warranty | Recalls / TSB 4 02-02-2014 02:27 PM
