Old 05-25-2016, 10:23 AM   #1
soilent
Drives: 2022 BRZ Premium
Been searching for this. Door and/or dash speaker crossover frequency??
I'm slowly putting together a new stereo system in my 2016 BRZ and this one question has been eluding me no matter how much I look around. I've figured out that the stock amp and/or headunit have crossovers built into them, but I have not been able to find out what frequency it's at.
Thus far I've installed a new amp and door woofers, but they currently kind of sound like crap because they aren't being crossed over and are playing full range.
Does anyone know where the door and dash speakers crossover with each other?? I have to assume it's somewhere between 500-800hz~ please help!
soilent is offline   Reply With Quote
Old 05-25-2016, 11:28 AM   #2
Chimera
Drives: FRS
I tried to figure this out once, the dash gets full as well, and has caps, I tried to look once but the caps either are not labeled with the capacitance, or the label is glued to the body. as far as the stock amp goes, someone really bored with an Oscope would have to figure that out. If I had an Oscope I guess I could figure it out. who wants to buy me an Oscope?
maybe someone else knows
Old 05-25-2016, 11:35 AM   #3
soilent
Haha yeah, I keep seeing your posts when I search for this. Someone's got to know. This is so annoying!
Old 06-05-2016, 07:28 PM   #4
soundman98
ProCrastinationConsultant
soundman98's Avatar
here's a cheap one, you can still do it yourself!
https://www.sparkfun.com/products/11702
Old 06-05-2016, 07:48 PM   #5
scirocco78
Drives: Scion FRS
Frs tweeter 2.7 uF cap
Frs mid 10 uF cap
I have't pulled the door speakers but I have always assumed they were actively crossed over by the amp.
scirocco78 is offline   Reply With Quote
Old 06-05-2016, 10:29 PM   #6
soundman98
soundman98's Avatar
Frs mid 10 uF cap
i don't believe the door speaker have any correction applied to them. they definitely don't have any crossover components. i believe they are just full range.
Old 06-06-2016, 07:42 PM   #7
TOOSTUBBORN2FAIL
Drives: Specialized Hardrock
They wouldn't have any crossover components if they were crossed over by the amp.
TOOSTUBBORN2FAIL is offline   Reply With Quote
Midrange speaker in dash? yomchi1989 AUSTRALIA 59 10-15-2022 03:39 PM
Atermarket Speaker crossover install location AL008 Electronics | Audio | NAV | Infotainment 9 10-17-2016 11:37 PM
VIDEO GUIDE - Build your own door speaker mounts using the factory speaker shells. The Sentinel DIY (Do-It-Yourself) Guides 3 01-28-2016 05:39 PM
Stock Stereo/Headunit Frequency Crossover? Replacement Door Woofers PandaSPUR Electronics | Audio | NAV | Infotainment 3 01-12-2015 02:18 PM
Would coaxial door speakers plus stock tweeters be too much high frequency sound? Prog Electronics | Audio | NAV | Infotainment 4 12-27-2013 07:15 PM
