Old 01-12-2015, 11:16 AM   #1
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Stock Stereo/Headunit Frequency Crossover? Replacement Door Woofers
I might be completely mistaken here, but does the stock stereo have a pre-set crossover frequency thats hardwired somewhere?
As in the signals to the door woofer, for example, are cut off to be only a certain range of frequencies.
I want to upgrade just the door woofers on my BRZ since I'm overall pretty satisfied with the system. I'm just trying to figure out if it would make a difference or not.
Specifically looking at these three replacements right now:
[ame="http://www.amazon.com/dp/B002C8AFEE/"]Amazon.com : Infinity Reference 6032si 6.5-Inch, Shallow Mount High Performance 150-Watt Two-Way Loudspeaker (Pair) : Vehicle Speakers : Car Electronics[/ame]
[ame="http://www.amazon.com/dp/B003KN2TF8"]Amazon.com : JBL GTO638 6.5-Inch 3-Way Speakers (Pair) : Vehicle Speakers : Car Electronics[/ame]
[ame="http://www.amazon.com/dp/B00ANIECRQ"]Amazon.com: JBL GTO629 Premium 6.5-Inch Co-Axial Speaker - Set of 2: Car Electronics[/ame]
PandaSPUR is offline   Reply With Quote
Old 01-12-2015, 12:09 PM   #2
Porcupint
Drives: 13 GBS BRZ
Door woofers are powered through the OEM amplifier. As far as I know, the head unit puts out a full signal to the amp and the amp does all the filtering if any.
For some reason your links aren't working for me. But you would probably need more power than the OEM amp provides to really get the most out of those speaker you're listing.
Porcupint is offline   Reply With Quote
Old 01-12-2015, 12:31 PM   #3
PandaSPUR
PandaSPUR's Avatar
Yea... the forums broke the link and I cant seem to fix it, an extra "/" got added into the URLs for some stupid reason.
Anyway, so does the stock amp do any filtering?
And the speakers I listed are 2ohm, 2ohm, and 3ohm impedance, so I thought they could still be run off of the stock amp since the stock door woofers are 2ohm. I've definitely seen a few posts around here about people using the Infinity's I linked. Will have to do more research on the JBLs.
Old 01-12-2015, 02:18 PM   #4
Chimera
Drives: FRS
Stock amp does filter signal. idk what range exactly.
Would coaxial door speakers plus stock tweeters be too much high frequency sound? Prog Electronics | Audio | NAV | Infotainment 4 12-27-2013 07:15 PM
Part number for 2014 Stereo Headunit jflogerzi Electronics | Audio | NAV | Infotainment 84 06-19-2013 06:00 PM
FS: OEM FR-S Headunit + Door Speakers CamryDS Audio/Visual, Electronics, Infotainment, NAV 4 05-19-2013 05:24 PM
iPad mini - now a possible replacement for the stereo. kappaknight Electronics | Audio | NAV | Infotainment 32 02-11-2013 11:59 PM
FR-S headunit replacement drei CANADA 7 07-11-2012 04:08 PM
