| Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) Wash, Wax, Details, Repairs |
Drives: 2015 BRZ Limited
Bad touch up pen repair job - Need adivce
Someone recently scraped my front bumper in a parking lot. I impulsively (and clumsily) tried to hide the scrape using an OEM touch up pen. The scrape now looks arguably worse than before my "fix" - it looks almost like jam smeared messily on a piece of toast. I even got some touch-up paint on parts of the bumper that wasn't scraped.
What's my best course of action? I would like to try and properly repair this myself if possible (with better preparation this time, of course), although I have no experience with this sort of thing. Also keep in mind that I have the new '15 WRB, which is a tri-coat paint. If I were to take it to a body shop instead, how much should I expect to pay? |
Touch up pens are for small chips not big spots like that. You could try wet sanding that and try to level it out but it will never be great. You could also sand it down and order a spray can which will give better results but still be far from perfect. The only way that you will get 100% is from a body shop. Prices can have a huge range and that could go anywhere from about $200 to $1000. Check your local shops and make sure they know you are paying out of pocket since they charge less than if insurance is paying.
Hello Snornex and welcome to ye ol forum ......
![]() Yep, you messed up that paint job pretty good ...... what did you apply the paint with ...... a broom .. ?? (jest ah messen wich ya) Like ol @Tcoat suggests, you could take off what you put on there, lightly sand it and give it another go (be sure you take all the old wax off with isopropyl alcohol). Then, after a week or so, if you still notice it ...... have a body shop fix it proper. Just keep in mind ...... the FIRST scratch is the most painful ...... ![]() humfrz |
Drives: 2015 GTI
If you used one of those duplicolor pens or whatever, just use rubbing alcohol and the touch up paint will come right off.
2013 GTI - Gone
2015 GTI |
Thanks guys. I'll give rubbing alcohol + light sanding + repaint a try, and if it still doesn't work I'll look around for a good body shop.
#6 | |
![]() humfrz |
Drives: 2015 BRZ Series Blue WRB
I would try a light sandpaper with a buffer. But if you do not have experience working with the buffer, go a bodyshop. Else you probably will mess up even more.
Drives: '16 BRZ
I think your best bet is to bring it to a body shop. Will cost more but you can be sure that the result is great.
| I Believe I can FLY. I believe I can touch the sky. I think about it every night &day | Mr. | Exterior Parts (Aero, Lighting, Etc.) | 10 | 02-18-2016 01:03 AM |
| Why does everyone touch my car? | LS1M | BRZ First-Gen (2012+) — General Topics | 49 | 06-13-2015 05:29 PM |
| Touch nav system! | madfast | Electronics | Audio | NAV | Infotainment | 102 | 09-03-2013 02:48 PM |
| Touch up paint | Simpleviet | Northern California | 11 | 03-20-2013 07:55 PM |
| Where to buy touch up paint? | czar07 | AUSTRALIA | 10 | 11-10-2012 07:13 AM |
