Old 05-24-2016, 06:20 PM   #1
RichardJ
RichardJ's Avatar
Drives: 15' FRS
Diasbled Loud Cold Start with OFT
Hello!
The moment I received the OFT tablet, I flashed the car with the stage 1 91 tune and loved the subtle but effective differences the tune gave the car.
The first thing I wanted to was to make the cold starts less obnoxiously loud every morning. I just have a catback which happens to be on the loud side and I would rather stay friends with my neighbours.
I followed one of the threads and ended up modifying tables as such using RomRaider.
I read somewhere to change all 1400+ to 1400 but even that was loud so I opted for 1200. Is it safe? Or should I leave the Idle Control values as it is on the stock map?
I am a complete noob on OFT related things and this is my first attempt on doing anything related to it. Please understand if changing that was completely idiotic!
I would greatly appreciate it if you guys had a look at it. Thank you!
RichardJ is offline   Reply With Quote
Old 05-25-2016, 12:26 AM   #2
steve99
yes dropping max idle rpm to 1200 should be ok
you might want to leave a little more maf compensation in at very low temps
also the post ignition timing try using -4 or -6 degrees you have a positive value in their, it will work but it tends to sound realy crap once you reduce the retard beyond about -4 (originally it was -15)
just be carefull and make sure you get the decimal points and the minus signs in where they are supposed to be else weird stuff will happen
Old 05-25-2016, 04:23 PM   #3
RichardJ
RichardJ's Avatar
Drives: 15' FRS
Thank you so much!
I changed the MAF Correction after cold start for both Neutral and In Gear for 14F to 9 g/s. Not sure if 'very cold temps' were referring to that row only.
Also why is it only necessary to change Idle Control Target A and E? Tried starting the car and idled at 1500 rpm.
Thank you so much for your reply
Old 05-25-2016, 05:11 PM   #4
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by RichardJ View Post
Thank you so much!
He meant idle tables A-E (essentially all of them)
Old 05-25-2016, 06:00 PM   #5
steve99
correct you need to do all idle tables .
Old 05-26-2016, 11:31 AM   #6
RichardJ
RichardJ's Avatar
Drives: 15' FRS
Everything works now thank you guys!
Old 03-10-2017, 01:50 PM   #7
Imranman
Drives: 1991 Acura NSX
Question: I changed the idle to 1400 and the ignition timing to -4 (it goes to -3.83 when I do) but now my throttle feels like I need to hit it a bit harder to get the car moving to the point I even stalled once. Does anybody know why the throttle sensitivity would have changed?
Imranman is offline   Reply With Quote
Old 03-10-2017, 02:00 PM   #8
Chimera
Drives: FRS
throttle learning position on the drive my wire throttle is reset on every ecu flash. it learns again each time. same thing happens on battery pull. drive it around a bit, it'll fix itself. its way better than old Toyotas.. has an old Yaris, on battery replacements it was like impossible to drive.
Old 03-10-2017, 02:02 PM   #9
Imranman
Ahh ok thanks!
Loud misfires upon cold start connorlug Issues | Warranty | Recalls / TSB 42 03-31-2016 04:43 PM
Cold Start, engine makes loud pop sound BTXP.XD Issues | Warranty | Recalls / TSB 10 05-20-2015 10:32 PM
LOUD KNOCK during cold start Flat_4_Life Issues | Warranty | Recalls / TSB 23 03-18-2015 05:30 PM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 05:05 PM
Loud cold start and mpg drop since new be6sti Issues | Warranty | Recalls / TSB 7 11-28-2012 01:35 PM
