Old 05-23-2016, 10:51 AM   #1
radroach
Drives: car
Rear bumper body repair respray question
I'm wondering what would be the best paint product for the brz rear bumper repair, GBS color. Can anybody recommend a good color matched product?
Car was tapped while parked. I have a some cracked, chipped paint and a small protrusion maybe 1"1/2 inch across. I'm thinking of taking on with a spot repair with the bumper removed and using the following tools: hand sanding 20, 180, ~~ 1000, 3000 grit sandpaper, heat gun, bondo (or other filler).
Old 05-23-2016, 10:55 AM   #2
jasonojordan
Drives: 2013 satin white brz limited
Ive never found a color matched spray can that turned out decent. I would just have it claimed on the persons insurance that hit you or was it a hit and run?
jasonojordan is offline   Reply With Quote
Old 05-23-2016, 02:22 PM   #3
humfrz
Do you have a picture for us ..... ??
I have a suspicion that you are not going to be happy with the outcome, unless you have the entire bumper re-sprayed......
humfrz
Old 05-23-2016, 03:04 PM   #4
Leonardo
Country Boy 4 Life
Leonardo's Avatar
HERE:
http://www.automotivetouchup.com/
I ordered sand paper, adhesion promoter, color, clear, primer, prep solvent, tape, and a sticky rag. Basically everything but a spray mask. Be patient, wait between coats. Better to do three light coats than one thick... Sand the primer. Have fun! wear a mask!
Edit: I heat my spray cans in a cooler of hot tap water. Dry them off before use with compressed air. Try and paint at above 60F outside temp for best results.
Old 05-23-2016, 03:05 PM   #5
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
that stuff works amazing^^ i use it on all my older cars.
797Performance.com
nickmerronesucks is offline   Reply With Quote
Old 05-23-2016, 05:41 PM   #6
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
HERE:
This. I redid my entire front bumper myself and it came out solid. It took me 15 hours in total (LOTS of sanding), but worth it. You need everything from the above list, but add in wax/grease remover. Also, PURCHASE A GOOD CLEAR COAT. Don't use things that come in kits -- Either buy a proper spray gun and proper 2 stage clear, or buy SprayMax2k in a rattle can.
EDIT: +1 for wearing a mask. 2 stage clear coat CAN kill you if you aren't careful.
ajcarson11 is offline   Reply With Quote
Old 05-24-2016, 01:02 PM   #7
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
with the grits you have listed, you're already in over your head. spot blends are pretty hack-ish, but they can look decent enough to get you by if that's all you're looking for. proper repair would be removing bumper. masking off lower section (non removable). repairing damage/spot prime. prep bumper. blend base coat. clear whole cover. install.
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 05-24-2016, 07:45 PM   #8
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
I'd recommend to get it all painted or put some decals.
Color matching is tricky and unless you doing like 1/2 bumper, imo not worth putting in the work.
Packofcrows is offline   Reply With Quote
Old 06-02-2016, 04:51 AM   #9
wil5bart
Drives: '16 BRZ
Paintscratch can also match the paint. Bought from them before and I can say that they did a good job in matching the color and the quality of paint is good.
wil5bart is offline   Reply With Quote
Bumper paint not matching after respray kylega Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 09-22-2015 04:20 PM
Rear bumper paint repair Mbaker Southern California 6 05-26-2015 04:15 PM
Rear bumper repair body shop near Philadelphia, PA bayank NY / NJ / CT / PA 1 01-13-2014 08:17 PM
scuffed bumper repair question brillo Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 07-12-2013 11:55 PM
Question about professional body repair FRiSson Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 8 03-14-2013 06:25 PM
