| Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) Wash, Wax, Details, Repairs |
Drives: car
Rear bumper body repair respray question
I'm wondering what would be the best paint product for the brz rear bumper repair, GBS color. Can anybody recommend a good color matched product?
Car was tapped while parked. I have a some cracked, chipped paint and a small protrusion maybe 1"1/2 inch across. I'm thinking of taking on with a spot repair with the bumper removed and using the following tools: hand sanding 20, 180, ~~ 1000, 3000 grit sandpaper, heat gun, bondo (or other filler). |
#2 |
Drives: 2013 satin white brz limited
Ive never found a color matched spray can that turned out decent. I would just have it claimed on the persons insurance that hit you or was it a hit and run?
#3 | |
I have a suspicion that you are not going to be happy with the outcome, unless you have the entire bumper re-sprayed...... ![]() humfrz |
#4 | |
Country Boy 4 Life
HERE: http://www.automotivetouchup.com/ I ordered sand paper, adhesion promoter, color, clear, primer, prep solvent, tape, and a sticky rag. Basically everything but a spray mask. Be patient, wait between coats. Better to do three light coats than one thick... Sand the primer. Have fun! wear a mask! Edit: I heat my spray cans in a cooler of hot tap water. Dry them off before use with compressed air. Try and paint at above 60F outside temp for best results. Last edited by Leonardo; 05-23-2016 at 03:14 PM. |
| The Following User Says Thank You to Leonardo For This Useful Post: | nickmerronesucks (05-23-2016) |
#5 |
Ned flanders
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
that stuff works amazing^^ i use it on all my older cars.
797Performance.com
| The Following User Says Thank You to nickmerronesucks For This Useful Post: | Leonardo (05-23-2016) |
#6 | |
Drives: 2013 Subaru BRZ Limited (Black)
EDIT: +1 for wearing a mask. 2 stage clear coat CAN kill you if you aren't careful. |
| The Following User Says Thank You to ajcarson11 For This Useful Post: | Leonardo (05-23-2016) |
#7 |
Drives: 2JZ FRS
with the grits you have listed, you're already in over your head. spot blends are pretty hack-ish, but they can look decent enough to get you by if that's all you're looking for. proper repair would be removing bumper. masking off lower section (non removable). repairing damage/spot prime. prep bumper. blend base coat. clear whole cover. install.
#8 |
hey you, yeah you <3
Drives: 2014 37J FR-S
I'd recommend to get it all painted or put some decals.
Color matching is tricky and unless you doing like 1/2 bumper, imo not worth putting in the work.
#9 |
Drives: '16 BRZ
Paintscratch can also match the paint. Bought from them before and I can say that they did a good job in matching the color and the quality of paint is good.
| Bumper paint not matching after respray | kylega | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 11 | 09-22-2015 04:20 PM |
| Rear bumper paint repair | Mbaker | Southern California | 6 | 05-26-2015 04:15 PM |
| Rear bumper repair body shop near Philadelphia, PA | bayank | NY / NJ / CT / PA | 1 | 01-13-2014 08:17 PM |
| scuffed bumper repair question | brillo | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 1 | 07-12-2013 11:55 PM |
| Question about professional body repair | FRiSson | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 8 | 03-14-2013 06:25 PM |
