Old 05-22-2016, 02:49 AM   #1
steve86gt
Drives: 2014 Toyota gt86 avo stg 2 e85
Motul 5w-40 Oil for turbo engine
Hi all,
Ive done a ton of searching about this but no one really gives an answer with a explanation
I have just taken my car to get a service and a few bits and pieces installed
They have put Motul 5w-40 oil into my engine , has anyone run this ?
Thanks in advance
steve86gt is offline   Reply With Quote
Old 05-22-2016, 07:35 PM   #2
SirSpectre
Drives: 2013 Hot Lava FRS
Seems like a good decision to me. I run Rotella T6 10w-40. Turbo oil temps get hot So 40 will survive a little longer and keep viscosity better.
SirSpectre is offline   Reply With Quote
Old 05-22-2016, 08:14 PM   #3
Tenino
Drives: 13' BRZ
Originally Posted by steve86gt View Post
Hi all,
Thanks in advance
You'll be fine, 30 to 40 weight oil is recommended for forced induction setup. It also helps with loss in oil pressure.
Think you mean Shell Rotella T5 if you're running their "10w" 40.
Tenino is offline   Reply With Quote
The Following User Says Thank You to Tenino For This Useful Post:
JazzleSAURUS (05-24-2016)
Old 05-22-2016, 08:16 PM   #4
jerbull
Drives: 2013 FRS Asphalt
T6 is 5w40
jerbull is offline   Reply With Quote
Old 05-23-2016, 04:43 AM   #5
steve86gt
Thanks for that guys, i feel alot better now
Temp usually stays around 95-100c
Old 05-23-2016, 11:14 PM   #6
stevo585
Drives: White 2014 BRZ
That temp is fine for a 20 or 30 wt oil.
JDL Turbo kit - Ecutek, HRI tuned.
stevo585 is offline   Reply With Quote
Old 05-24-2016, 01:11 PM   #7
denso
Drives: 86
Im on Motul 300v 5W-40 - no problems.
denso is offline   Reply With Quote
The Following User Says Thank You to denso For This Useful Post:
Raven86Project (08-19-2018)
Old 05-24-2016, 01:13 PM   #8
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
I tun 5w40 T6 in my built motor Forester XT.
Fantastic oil for turbocharged engines, and 5w40 is a great weight. Motul is also world class so I would be very happy with that change personally. A bit more expensive if you do frequent changes.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
FS: Motul engine oil, brake fluid, coolant and gear oil Jesse0923 Mechanical Maintenance and Tools 7 09-07-2019 10:05 AM
CounterSpace Garage || Jackson Racing Oil Cooler | Motul Engine Gear Oil Packages || CounterSpace Garage Engine, Exhaust, Bolt-Ons 41 07-08-2016 04:19 PM
motul 300 vs motul 300ls about to buy some need help. NickFRS Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 03-24-2016 10:51 PM
Best Oil for turbo engine. gdrider77 Forced Induction 102 03-15-2016 01:43 PM
