Old 05-21-2016, 11:09 AM   #1
WestO_FRS
FRS with no programmer
I'm looking at a FRS with a Vortech supercharger at a dealer, however it has no programmer. No Ecutek or oft is with the car and they cannot get a hold of the previous owner. If I decide to get it is there anything that could be done with the tune? If I get another programmer is is there a way to reflash if needed?
WestO_FRS is offline   Reply With Quote
Old 05-21-2016, 02:14 PM   #2
skye67
skye67's Avatar
Drives: 2013 black AT, OFT, 4.65
I would say tell Them to knock off couple thousand dollars off the car and get a programmer and you should be good to go. as long as the SuperCharger doesn't have substantial changes from its standard setup. but it still could be a big crap shoot with the car modified like that.
Living the dream in a nightmare.
skye67 is offline   Reply With Quote
Old 05-21-2016, 04:01 PM   #3
WestO_FRS
If it was an ecutek tune will I just be able to get another cable and tune it?
Old 05-21-2016, 04:52 PM   #4
steve99
Ok
If its an opensource tune like OFT or Tacrix then ECU is not locked and you can use any tune system to reflash or alter the existing tune.
If its Ecutek tune then ECU is locked to ecutek, so you would need to use an Ecutek tuner or buy an ecutek cable to be able to access ecu to retune or unlock the ecu back to stock or unlocked state.
If its BRZEdit tune then its locked to brzedit so again you need to use brzedit tuner or buy brzedit to access ecu to retune or return to stock unlocked state
The thing that sucks is their is no easy 100% way to tell which system has been used until you start trying the different systems and see which connects. and brz edit wont unlock ecutek and vice versa.
Old 05-21-2016, 05:17 PM   #5
skye67
skye67's Avatar
Ok
Yeah! what he said! Additionally you never have a stock tune to revert the car back too. This is the problem when you buying a modded car. You don't know what the other guy's done to it before you get it.
Old 05-21-2016, 05:47 PM   #6
churchx
churchx's Avatar
Drives: 2014 GT86
.. unless previous owner was courteous and provided all info. Seriously - how hard can it be to tell such simple things for next owners? Or leave paper print out with that info if sale goes through some interim sellers?
Old 05-21-2016, 05:54 PM   #7
steve99
getting stock tune is not a problem brzedit and ecutek systems have them and ive posted most of them up in the Tactrix thread linked below for opensource guys
Old 05-21-2016, 11:36 PM   #8
D_Thissen
D_Thissen's Avatar
The fact that the dealer can't get a hold of the previous owner means that purchasing that car could be a huge gamble. For all you know, that car could be on the stock tune.
Old 05-22-2016, 11:03 PM   #9
MGPAX
Still 17!
MGPAX's Avatar
Drives: 2014 Silver BRZ Limited
If the dealer can't get a hold of the previous owner, it was probably an Auction buy.....
'14 BRZ LIMITED-OFT (W.W. TUNED)-PERRIN-K&N-WHITELINE-DIODE DYNAMICS-GRIMMSPEED-REXSPEED-FT86-TAPTAP-OLM-GOODYEAR-OSRAM-WEIR-ENKEI-TOMEI EL
MGPAX is offline   Reply With Quote
Old 05-23-2016, 02:28 PM   #10
WestO_FRS
I called to ask if they go in touch with the previous owner and they said the car sold over the weekend. I'm guessing they didn't
Old 05-23-2016, 03:02 PM   #11
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
was it by any chance grey with carbon fiber bits ?
797Performance.com
nickmerronesucks is offline   Reply With Quote
2015 BRZ Programmer? mybapes23 BRZ First-Gen (2012+) — General Topics 10 03-12-2015 09:20 PM
True or Scam? High Performance ECU programmer chip works? Bmore_Raven86 Engine, Exhaust, Transmission 13 12-14-2013 02:01 AM
Programmer's Thread (JS, Ruby, Python, PHP, HTML, C#, jQuery, etc) RAYSSPL Off-Topic Lounge [WARNING: NO POLITICS] 59 06-18-2013 02:55 AM
