Drives: 2014 SSM BRZ
Any clear BRZ side marker / blinkers that don't leak?
I'm looking for new clear BRZ side markers that will blink (I like the extra safety from that amongst other reasons).
I previously bought and installed iJDMTOY side markers but they leaked and died. They wouldn't honor the warranty either. So now I'm looking for something that's quality, and works. I was looking at these Razer Auto side markers: [ame="http://www.amazon.com/Razer-Auto-2013-2015-Subaru-Blinker/dp/B00W2MQJAY"]Amazon.com: Razer Auto 2013-2015 Scion FR-S & Subaru BRZ ZC6 White/Amber LED Front Bumper Side Marker Blinker Lights, JDM Crstal CLEAR LENS & BLACK BASE: Automotive[/ame] ![]() Has anyone installed them? My specific questions about those: - Do they leak? - Is the installation straight forward? - How do they look? Do they stick out too far? - Are they similar in color when lit to the headlights, etc.? I would just like some nice, clear side markers with blinker functionality. If anyone has pictures and/or videos to share, that'd be great!
Drives: Subaru BRZ
Why not go for OEM European spec?
Thanks
Can't you just carry extra blinker fluid and replace it as it leaks out?
| The Following 14 Users Say Thank You to ZionsWrath For This Useful Post: | 15limited (05-21-2016), CatalystPLUR (05-26-2016), gramicci101 (05-18-2016), Harjotdhanota (10-29-2017), hypebrz (05-18-2016), jasonojordan (05-18-2016), JD001 (05-19-2016), JD86 (05-18-2016), Kaotic Lazagna (05-18-2016), meWant (06-08-2016), mgarcia707 (07-20-2018), Mr.ac (06-05-2016), Psilox (02-08-2017), XanRules (05-18-2016) |
Drives: FRS
i got a pair of jdm clears and no problems so far and its been over 2 years
| The Following 2 Users Say Thank You to 8R6 For This Useful Post: | SkAsphalt (05-18-2016), ZionsWrath (05-18-2016) |
Thanks
This, buy the highest quality lighting products you can afford. Cheap ebay stuff leaks, peels, poor output, hazes over. OEM usually has the best quality in my experience. I'd take parts of a junkyard car before new ebay crap.
Oem jdm.
I have helix light smoked and they don't leak, but others have the same and they have leaked. |
| The Following User Says Thank You to swarb For This Useful Post: | ZionsWrath (05-18-2016) |
The Fail Boat
Drives: CWP S.B.
get the jdm oem toyota subaru one you dumb dumb...
| The Following User Says Thank You to chaoskaze For This Useful Post: | SkAsphalt (05-18-2016) |
Huge E85 fan!
Drives: 2016 Scion FRS
The full synthetic blinker fluid tends to leak. Try a thicker non-synthetic with a stabilizer additive or the high mileage blinker fluids usually have the additive already.
If this doesn't do it, then your seals may be blown & you'll need a blinker rebuild. Good luck |
| The Following 3 Users Say Thank You to guybo For This Useful Post: |
Drives: 2015 BRZ Limited
You can also do some preventative maintenance. My first set of helix markers leaked. With my second set, I put a thin layer of clear silicone around the sides and any location where parts connect. When I inserted the LED, I wrapped electrical tape from the housing to about 2 inches down the wire.
So far so good. We've had some torrential rain storms and it also made it through the entire winter. |
#10 |
Drives: DGM BRZ
I sealed mine with silicone around the edges where the plastic connects the moment I got them. Never had any issue. That being said, I live in California, so I don't get real rain.
#11 |
OEM clear ones.
#13 |
I like oem. I'm definitely for quality. But they don't blink do they? Aren't they just solid running lights?
I'm not a fan of doing wiring, etc. And I'm very novice. It's there a way to make oem side markers blink?
#14 |
Drives: Brz
The sidemarkers do not blink and you cannot make them. Frs jdm clear ones are the best quality and will hook up nicely. No you do not have to wire it. It's plug and play
| Tags |
| blinker, clear side marker |
| DIY side marker blinkers | boonFRS | DIY (Do-It-Yourself) Guides | 112 | 06-08-2020 01:45 AM |
| WTB: Passenger Side Clear Side Marker | Sheepdog | Want-To-Buy Requests | 0 | 08-03-2015 08:56 PM |
| oem clear side marker | mush | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 01-27-2014 01:53 PM |
| FS: JDM clear side marker lights | ILL_86 | Exterior Parts (Aero, Lighting, Etc.) | 9 | 01-02-2014 05:17 PM |
| **GB Clear/Smoke LED Side Marker ** | nigel-jdmparts | Groupbuys | 484 | 07-07-2013 08:32 PM |
