Old 05-13-2016, 12:58 PM   #1
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
best double sided tape?
Can anyone recommend the best double sided tape or some similar solution? I have gotten a few used parts from japan that had what looked like some sort of puddy in small circles that i guess they used to hold on panels.
I just picked up my car from the body shop after being hit and the replacement tape they used(my lip kit had tape from factory) doesn't seem to be holding up to nicely. tried heating and painters tape to see if i could save it but seems like its been on to long also they stacked like 3 layers of tape so i guess that probably doesn't help..
797Performance.com
nickmerronesucks is offline   Reply With Quote
Old 05-13-2016, 01:05 PM   #2
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
I usually use the 3M stuff. I put on my emblems with it and it's held up fine for years now.
Clueless
YamahaR86 is offline   Reply With Quote
Old 05-13-2016, 01:09 PM   #3
nickmerronesucks
Ned flanders
Just the regular old stuff from local auto parts place or is there a commercial grade one?
797Performance.com
Old 05-13-2016, 01:37 PM   #4
Si_Chris
Drives: 2016 ISM BRZ Limited, 2000 Civic SI
Try this stuff, they're available from any auto parts store:
The key issue is to make sure you prep both surfaces before installing. Make sure the surface is free of wax, dirt, and the temperature is warm. You can wipe down the panel with rubbing alcohol to get rid of wax on the paint surface.
Si_Chris is offline   Reply With Quote
Old 05-13-2016, 01:41 PM   #5
NahumCC
Drives: 2013 FR-S 10 Series
This is what I'm using to. I'm just waiting on some 3M adhesion promoter to come in the mail and then I'll start by cleaning both surfaces with isopropyl alcohol followed by the adhesion promoter.
NahumCC is offline   Reply With Quote
Old 05-13-2016, 01:47 PM   #6
YamahaR86
YamahaR86's Avatar
Drives: 2013 White
Stuff from the auto store or amazon that @Si_Chris linked. It's grey double sided and has the red plastic that you take off.
I think the downside is it's a little on the thick side but that's the trade off for super sticky. If you use commercial grade for aircraft/VHB then you'd need a razor blade to remove it and it may damage the paint.
Clueless
Old 05-13-2016, 10:48 PM   #7
amartinez9881@gmail.com
amartinez9881@gmail.com's Avatar
Drives: Scion FRS
hey i had same issue with my lip kit ( HTAutos) i honestly think best bet avoid the tape and try to get screws in it you will really i better
amartinez9881@gmail.com is offline   Reply With Quote
Old 05-13-2016, 10:53 PM   #8
Drives: Scion FRS
some pics
i used 3m tape help for abit after i did vinyl job but after a week or two it started to come off , went to mechanic paid ten bucks got a few screws in and good as new
Old 05-14-2016, 11:43 AM   #9
Seba
Drives: BRZ Cosworth SC MY16
I'm installing my rexpeed cf lip today. I'm using screws and 3M VHB double side tape. It's a 3M VHB 4991F acrylic tape. The tape is 2,3 mm thick and spongy, so it adapts very nicely. I have cleaned both surfaces with ipa. Right now i'm applying pressure with 6 car lifters for 12 hours.
Seba is offline   Reply With Quote
Old 05-14-2016, 12:00 PM   #10
Norville Rogers
Drives: Subaru BRZ
Take it back to the bodyshop?
Norville Rogers is offline   Reply With Quote
Old 05-14-2016, 01:17 PM   #11
Knshro13
Drives: 10 series FRS
3M VHB tape.
Knshro13 is offline   Reply With Quote
Old 05-14-2016, 10:56 PM   #12
nickmerronesucks
Ned flanders
Don't feel like doing it. Only reason it was at a body shop is because of an accident that i coulnd't repair my self..If they couldn't install them correctly once, why would I want them to do it again. Plus the 40 minute drive and I would have to drop it off im sure. Id rather save the hastle and do it my self.
797Performance.com
Old 05-14-2016, 11:59 PM   #13
soulreapersteve
Contract? /人◕ ‿‿ ◕人\
soulreapersteve's Avatar
Another vote for 3M VHB.
The Twins make me smile
Two-Sided tape for Aero parts Freude am Fahren Cosmetic Modification (Interior/Exterior/Lighting) 9 12-15-2017 05:39 AM
Double sided tape wootwoot Cosmetic Modification (Interior/Exterior/Lighting) 12 07-14-2015 09:58 PM
Double sided tape for spoilers? MileHighBRZ Scion FR-S / Toyota 86 GT86 General Forum 21 05-20-2015 12:47 AM
3M double sided tape for FR-S emblem denverizzles Cosmetic Modification (Interior/Exterior/Lighting) 0 07-19-2012 11:03 PM
