Old 05-11-2016, 12:05 PM   #1
LuisAntonioSG
Drives: 2014 brz
Unhappy What should i do with my chirping engine?
So after so many miles, my engine just started chirping... It's VERY annoying and it has me pretty frustrated. engine is sitting on 89,113 miles. Based on what i've read online, it's an unfixable problem. Should i swap my engine for the same one? or should i swap for a 2jzGTE? i would definitely appreciate any advice that will help me with this!
LuisAntonioSG is offline   Reply With Quote
The Following 2 Users Say Thank You to LuisAntonioSG For This Useful Post:
JoeC (05-11-2016), MisterSheep (05-11-2016)
Old 05-11-2016, 12:13 PM   #2
humfrz
YIKES! ...... 89,113 miles and you are just now posting to the forum ....... how on earth have you managed ........
So, the "crickets" found your engine ....... hmmmm took them long enough .....
Have you changed your source/grade of gasoline lately ...... if so, I suggest you change back.
Some folks put some sort of snake oil in their gas ...... with mixed results.
Some folks have their fuel pump changed out ....... but the new one usually gets infested.
My suggestion is that you just drive the car ....... there is really nothing wrong with it.
humfrz
The Following 8 Users Say Thank You to humfrz For This Useful Post:
Borrowed Time (05-11-2016), Chrisgalactic (05-12-2016), Cole (05-11-2016), fumanchu1 (05-11-2016), Jfheisenberg (05-11-2016), MisterSheep (05-11-2016), Shedd22 (05-12-2016), soulreapersteve (05-11-2016)
Old 05-11-2016, 12:15 PM   #3
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
Totaled.
"Practice makes better. Only Senna is perfect." - CSG Mike
LOLS2K is offline   Reply With Quote
The Following 8 Users Say Thank You to LOLS2K For This Useful Post:
86kahl (05-12-2016), 8R6 (05-11-2016), Chrisgalactic (05-12-2016), Cole (05-11-2016), frznBRZ (05-12-2016), pushrod (05-11-2016), smg1138 (05-12-2016), whataboutbob (05-12-2016)
Old 05-11-2016, 12:22 PM   #4
LuisAntonioSG
Drives: 2014 brz
I put in 93. although couple weeks ago i was running out of gas and the only thing close to me was a REALLY sketchy gas station that didn't even had the gas types marked (but i needed it bad) so i fueled the car and a few weeks later, my engine sounds like it has baby chicks or crickets under the hood x'D Also, i don't have alot of mods on it either. Only have a set of Perrin pulleys and short ram sp series injen intake.
Old 05-11-2016, 12:24 PM   #5
Zhangy
Drives: 2015 FRS
You will get used to the sound... just like how your snores will never wake you up
Zhangy is offline   Reply With Quote
Old 05-11-2016, 12:26 PM   #6
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
So the cricket noise isn't actually an engine issue, and is caused by your high pressure fuel pump. The noise is form the pump actually sticking for a quick second and is normally caused from the percentage of ethanol in gasoline that is found at pumps.
Instagram: trevor.parque
Antihero983 (05-11-2016)
Old 05-11-2016, 12:29 PM   #7
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
I've always questioned that it was the ethanol that caused this and not something else in the gasoline. It is purely anecdotal but my crickets come back in the winter when I switch back to pump gas but as soon as summer rolls around and I have a tank or two of e85 in there they disappear until winter again
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs
Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes
Tectoniic is offline   Reply With Quote
The Following 2 Users Say Thank You to Tectoniic For This Useful Post:
Antihero983 (05-11-2016), MisterSheep (05-11-2016)
Old 05-11-2016, 12:29 PM   #8
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
LSx swap it, throw a cam in it, enjoy life.
The Following User Says Thank You to Summerwolf For This Useful Post:
86kahl (05-12-2016)
Old 05-11-2016, 12:32 PM   #9
humfrz
Well now, lesson learned there ..... right .. ?? When you get stuck in a location that has only one gas pump and the ol boy only takes cash, just get a couple dollars worth and quickly find a real gas station.
Meanwhile, I suggest you hang on for another tank or two to see if the crickets go away. If they don't, just join the 50% (I just made that up) of the FR-S owners that just live with it........
humfrz
Old 05-11-2016, 12:32 PM   #10
MisterSheep
Killed Scion
I agree but that's what the other threads said... When I switched back from E85 to 91 I had crickets BAD and I'm not getting them while running strictly E85..
Tectoniic (05-11-2016)
Old 05-11-2016, 12:34 PM   #11
LuisAntonioSG
Drives: 2014 brz
I've always wanted to get a 2jz in there but everything is just soo expensive lol
Old 05-11-2016, 12:37 PM   #12
MisterSheep
Killed Scion
well the crickets isn't exactly a cause in order to engine swap. If you want to engine swap do it because you want something different. Who knows, if your new engine uses the same oem fuel pump then you might have crickets still!
Old 05-11-2016, 12:37 PM   #13
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Swap then sell to this guy!
http://www.ft86club.com/forums/showthread.php?t=105549
The Following User Says Thank You to mav1178 For This Useful Post:
86kahl (05-12-2016)
Old 05-11-2016, 12:41 PM   #14
Haeb
Haeb's Avatar
Drives: 2014 Scion FR-S Monogram Series
A good radio will solve this for you instantaneously
Haeb is offline   Reply With Quote
The Following 5 Users Say Thank You to Haeb For This Useful Post:
Jfheisenberg (05-11-2016), joe strummer (05-12-2016), MisterSheep (05-11-2016), soulreapersteve (05-11-2016), Tectoniic (05-11-2016)
annoying, chirping, engine, noise, sound
Engine idle chirping (cricket) noise poll. Hanzo Issues | Warranty | Recalls / TSB 5031 05-18-2017 09:41 AM
FYI Engine Chirping Fix pvtpile Hawaii 139 05-19-2015 05:42 PM
Did they come out with a fix for the engine chirping? redwing634 Issues | Warranty | Recalls / TSB 70 10-15-2013 01:18 AM
Can you hear chirping from my engine? 8987846 CANADA 4 06-28-2013 12:16 PM
Can you hear chirping from my engine? 8987846 Engine, Exhaust, Transmission 1 06-26-2013 11:15 PM
