Old 05-09-2016, 09:02 PM   #1
ansibe
Drives: White BRZ
Diff Fluid and Oversteer
I made several changes to my BRZ at once, and now I have a slight oversteer problem. Mods:
-dampers changed to Koni Yellow
-rear springs swapped to OE FRS (stiffer)
-Aligned to -1.5 camber and 0 toe all around.
-Diff fluid changed to Amsoil 75w-90 GL-4
-No change to the sways. I'm on OE BRZ
I Think the component changes are pretty conservative, so I'm surprised how much more oversteer I have. It's fun, but I'm not a drifter so I want grip.
Could this be caused by the diff locking early because of the fluid I'm using? I think I should have used GL-5.
ansibe is offline   Reply With Quote
Old 05-09-2016, 09:14 PM   #2
redlined600
redlined600's Avatar
Drives: Fr-s
If you have -1.5 camber front and rear I'm surprised you have oversteer. I'd start with a little toe-in in the rear. Maybe 1/8” total.
Is this a street only car?
Old 05-09-2016, 09:16 PM   #3
e1_griego
e1_griego's Avatar
Drives: Many
No, the fluid has nothing to do with it.
Also, torsens don't lock anyway.
Shock and rear spring change (and maybe alignment) are probably the cause. Also lots of time perceived handling ills are driver induced...
e1_griego is offline   Reply With Quote
The Following 2 Users Say Thank You to e1_griego For This Useful Post:
8R6 (05-10-2016), strat61caster (05-09-2016)
Old 05-09-2016, 09:28 PM   #4
ansibe
Drives: White BRZ
e1: Thanks for the advice.
Redlined: I do track days. The car actually feels loose mid corner now. Pre-mod, the car was locked down at the rear. More power resulted in more push. Kind of boring, but probably faster.
Old 05-09-2016, 09:33 PM   #5
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Your fluid choice have nothing to do with your oversteer, as others have stated. Stock Torsen doesn't care about what fluid you use.
-alex
Old 05-09-2016, 09:50 PM   #6
Tor
Tor's Avatar
Drives: Toyota GT86
Originally Posted by ansibe View Post
I made several changes to my BRZ at once...
...did you get an alignment? Sounds like it could be a toe problem. Did you check your tire pressure recently?
Tor is offline   Reply With Quote
Old 05-09-2016, 09:53 PM   #7
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Add a bigger front sway bar and 1/8 toe in the rear. That should sort it out.
smg1138 is offline   Reply With Quote
Old 05-09-2016, 09:56 PM   #8
mav1178
mav1178's Avatar
Also to answer your question:
1) one (or more) of your original shocks may have been bad
2) stiffer rear spring = oversteer
Assuming your alignment was done correctly, both of those could have been major contributing factors to your current oversteer "problem"
I am never a fan of changing more than one item at a time, especially if I drive the car daily or track it often. Wholesale changes are only necessary to fix something...
-alex
Old 05-09-2016, 11:53 PM   #9
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
What tire is it? Size& width? Or it's still stock?
Other then that maybe frs spring, tiny adjustments can still change the feel on this car a bit.
Old 05-10-2016, 12:50 AM   #10
ryoma
ryoma's Avatar
make the front dampers stiffer and/or soften the rear dampers. it's more of an experimental phase now so just try one change and drive it to see how you like it before making any more changes.
Old 05-10-2016, 01:28 AM   #11
NissanGuy
NissanGuy's Avatar
Drives: Strangely.
Q: Why do you install FR-S rear springs?
A: To induce oversteer.
The stiffer FR-S rear springs will induce oversteer, as will the hefty increase in front camber (stock is roughly zero) and the decrease in rear toe (stock is roughly 0.05 degrees). Add rear toe (OEM spec is good) and recheck. If still no good, change the springs back to BRZ.
My FR-S has a build thread!
(It's mostly full of Nissans)
NissanGuy is offline   Reply With Quote
The Following User Says Thank You to NissanGuy For This Useful Post:
strat61caster (05-11-2016)
Old 05-10-2016, 05:51 AM   #12
tyler_win_photo
tyler_win_photo's Avatar
Set the dampers in the front harder or the rear softer. Or more negative camber in the front.
tyler_win_photo is offline   Reply With Quote
Old 05-10-2016, 10:30 AM   #13
freerunner
freerunner's Avatar
Drives: GT86
The other way round.
freerunner is offline   Reply With Quote
Old 05-10-2016, 10:42 AM   #14
Racecomp Engineering
Agreed on the slight rear toe in being helpful.
Damper changes (stiffer front, softer rear) would be helpful on corner entry and exit.
- Andrew
Trans and Diff fluid change feedback Freedom AFRICA 0 08-07-2015 11:52 AM
Heres a tip on replacing diff fluid. Rick0S Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 0 07-27-2015 06:37 PM
Manual Trans./Diff. Fluid Change.?. westmansweed Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 07-15-2015 08:02 AM
Replacing Trans & Diff Fluid, Hot vs Cold BRZNutt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 12-22-2013 09:04 PM
Trans/Diff Fluid. DanoFA20 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 01-11-2013 03:11 PM
