Drives: 2013 FRS
Valenti Taillights and Backup lights
Im planning to buy valenti tail lights and the back up lights.
http://www.fteightysix.com/products/...s86z-hc-2.html Since I'm on a lease and I'm not 100% sure if I'm going to buy the car at the end of the lease, I want to know if you have to drill holes/cut wires to install these? If you do, would that affect me at the end of my lease term? I'm going to reinstall the stock ones IF I return it, but would the holes/cut wires affect the lease? |
#2 | |
JDM Vaping Stance Nation
Drives: 2013 White
Clueless
| The Following 2 Users Say Thank You to YamahaR86 For This Useful Post: | MisterSheep (05-09-2016), ThornhillSubaruOwner (05-09-2016) |
#3 | |
Killed Scion
Drives: 2013 FR-S Whiteout
Miyuki みゆき "Beautiful Snow" The Whiteout FR-S Instagram: trevor.parque |
| The Following User Says Thank You to MisterSheep For This Useful Post: | ThornhillSubaruOwner (05-09-2016) |
Drives: 2013 FRS
#5 | |
Drives: 2013 White
You could tap into the tail light's running + brake light since it connects to the OEM car wire, but I tapped into my car's OEM wire instead. Other than that, you just run the ground wire to the ground in the frame.
Clueless
| The Following User Says Thank You to YamahaR86 For This Useful Post: | ThornhillSubaruOwner (05-09-2016) |
Drives: 2013 White
Also, the rubber grommet for the weather seal, what I did was depin the stock connector, took it off and put the new one on/looped it in for an OEM look even though you can't see it.
Clueless
| FS: Valenti taillights in red | Reflex | NY / NJ / CT / PA | 6 | 07-04-2016 03:33 PM |
| Valenti taillights | swp subie brz | Exterior Parts (Aero, Lighting, Etc.) | 7 | 11-29-2014 09:00 PM |
| Valenti Taillights!!! | husker741 | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 11-07-2013 10:56 AM |
