Old 05-06-2016, 11:49 PM   #1
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
Well shit... Vortech oil dipstick stuck - head stripped
Posting this from the garage...
Anyone ever had issues getting their vortech oil dipstick off? I'm changing belts today, took the unit off just for convenience, and figured I'd change the oil while it was out. I put my 4.5mm wrench in there and SPIN, followed my gold metal shavings. It's been at least a year since I've had it off and theres been many track days and extreme heat cycles.
It's like... now what. Leave it on there I can still drive the car. Long term ideas anyone? I'm sure a guy can buy a replacement but how do you get it out now? I'll add pics later.
Thanks!
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
Old 05-07-2016, 02:46 PM   #2
Calum
That Guy
Drives: 2013 asphalt FRS MT
Thanks!
Hammer in a torx bit that's slightly bigger than the hole, make sure it's seated all the way. If that doesn't work, you'll be getting the extractor set and a drill.
Old 05-07-2016, 09:48 PM   #3
DJCarbine
Thupercharged
DJCarbine's Avatar
It's very soft material, as said above hammer in a torx bit.
Isn't the dipstick 3/16"? 4.5mm is a bit smaller by a few thousands
2013 FRS
Vortech V3 11psi
Old 05-07-2016, 11:22 PM   #4
Gopherboy6956
That's actually what I resorted to when the allen wasn't working. Stripped it clean around lol. What got me in my current predicament
That could be the reason I am having this problem in the first place, not using the correct size.
The Following User Says Thank You to Gopherboy6956 For This Useful Post:
nickmerronesucks (06-13-2016)
Old 05-08-2016, 05:10 AM   #5
avishenoy1
avishenoy1's Avatar
Drives: 2015 FR-S Release Series 1.0
https://www.google.com/shopping/prod...5T-_-205110987
avishenoy1 is offline   Reply With Quote
Old 06-13-2016, 11:39 AM   #6
Gopherboy6956
For Resolution - I was able to get a new dipstick, and used an extractor kit to remove the old one. Worked well.
Will be making sure to use standard allen when removing in the future, and probably not taking it out at the track
Stripped bolt head at over pipe/front pipe connection, what now? :( BBYZILA Scion FR-S / Toyota 86 GT86 General Forum 43 01-14-2019 06:13 PM
Dipstick question Qwimby2 BRZ First-Gen (2012+) — General Topics 26 11-27-2015 12:59 PM
transmission dipstick location ikeryder13 Engine, Exhaust, Transmission 28 06-11-2015 09:15 PM
oil on dipstick but not on hole ZionsWrath Engine, Exhaust, Transmission 2 09-08-2014 07:46 PM
Show me your dipstick.... Trashed675 Engine, Exhaust, Transmission 6 01-03-2014 01:09 AM
