Drives: GT86
Help: Cusco Engine Mount Install
Today, I tried to install a Paire of Cusco engine mounts to my car. I jacked up the engine through the oil pan with a trolley jack and a piece of block. All went smoothly until I tried to align the studs on the mimic ts to the subframe holes.No matter how hard I tried, the engine does not move a bit.
Does anyone have any ideas what should I do? Thanks a lot ![]() ![]() ![]()
Did you unbolt the 2 large nuts on the bottom of the front cross member, and then the 4 bolts holding the left and right mounts to the engine block....??
On the new ones. are you sure you have the "fronts" towards the front and the "right" on the right side (and the "left" on the other side ... )... ??humfrz Last edited by humfrz; 05-05-2016 at 08:18 PM. |
Drives: GT86
Yeah man, checked the orientation and it is all correct. Ended up using a pry bar to pry the mount until it aligned and had another person drop the trolley jack...all sorted now...cheers
| Perrin Engine Mounts and Cusco Catch Can Install and Review @ Pure Automotive | Pure Automotive | Engine, Exhaust, Transmission | 23 | 05-15-2016 04:21 PM |
| Help: Cusco Engine Mount Install | nichiolas | DIY (Do-It-Yourself) Guides | 1 | 05-06-2016 03:03 PM |
| Cusco Engine mount + CM FX350 = match made in heaven | rixter145 | Engine, Exhaust, Transmission | 3 | 01-16-2016 11:55 AM |
| cusco engine mount set $175 shipped | jah29 | Transmission and Driveline | 1 | 02-23-2014 09:21 PM |
| Perrin Engine Mounts and Cusco Catch Can Install and Review @ Pure Automotive | Pure Automotive | Mid-Atlantic | 9 | 01-31-2013 01:03 AM |
