Old 05-05-2016, 02:14 PM   #1
BRZ RN
BRZ RN's Avatar
Drives: Blue BRZ
Autocross brake pads
I'm currently using Hawk Performance plus brake pads, to those who are just on aftermarket brake pads, do you switch to oem pads after autocross day and switch back prior to another one, or you just let the autox pads sit? thank you
BRZ RN is offline   Reply With Quote
Old 05-05-2016, 03:23 PM   #2
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
I'm running stock pads, since they engage the ABS and handle the heat from 1 minute runs (just don't hold the brake down when staging after a hot run). For track days, I swap to XP8s, inspect the condition of the rotors and SS lines, and check/bleed the RBF600 fluid.
At autocross, your braking zones will be infrequent and tight. A pad with better initial bite can shave time (like the Ferodo DS2500, Carbotech AX6, ProjectMu HC800, Winmax W2)... but my skill level is chasing the final second, not the last tenth.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
The Following 3 Users Say Thank You to Shankenstein For This Useful Post:
BRZ RN (05-06-2016), Hyper4mance2k (05-08-2016), ZionsWrath (05-05-2016)
Old 05-05-2016, 03:41 PM   #3
Lets add G-Loc R6 to that list @Shankenstein
Old 05-05-2016, 03:44 PM   #4
ZionsWrath
Thanks
ZionsWrath's Avatar
Is that pad better than OEM yet quiet on street?
Old 05-05-2016, 04:26 PM   #5
wparsons
wparsons's Avatar
The G-Loc R6 should be pretty comparable to a Carbotech AX6.
flickr
Old 05-05-2016, 04:30 PM   #6
This. Minimal to no noise with proper bedding. I recommend using a shim and brake grease with these pads for street/autox use.
BRZ RN (05-06-2016)
Old 05-05-2016, 07:37 PM   #7
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Hows the inital bite of the R6 both hot and cold? That is one of the things I like best about the HC+800? And how is the dusting on them in relation as well?
Old 05-05-2016, 07:55 PM   #8
Slightly more initial bite cold, consistent bite through the range, slightly less dust. Dust is very easy to clean off, due to being chemically neutral.
finch1750 (05-05-2016)
Old 05-07-2016, 06:29 AM   #9
BRZ RN
BRZ RN's Avatar
Drives: Blue BRZ
my OP question was, do you exclusively use autocross pads for autocross or leave them up to the next autocross day? thank you
Old 05-07-2016, 09:16 AM   #10
cjd
cjd's Avatar
Drives: 2017 BRZ
I leave them despite being unable to permanently quiet them. I run AX6 at the moment.
Old 05-07-2016, 05:17 PM   #11
strat61caster
strat61caster's Avatar
I've got milder pads on right now that seem to do the job well enough (ns400) going to step up to one of the compounds here and suggested in other threads out of desire for more braking torque. Unless your autocross courses are bigger than national style with multiple hard third gear to second gear braking zones you shouldn't need a pad that's unstreetable.
OEM is probably a good fit if your courses are all second gear and <60s on stock power and street tires.
Edit: also implying OEM like and street pads, ns400, carbotech 1521, w2/3, stop tech, TRD, etc
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
BRZ RN (05-07-2016), CSG Mike (05-08-2016)
DIY - Changing Your Brake Pads (Race Pads upgrade) PMok DIY (Do-It-Yourself) Guides 53 09-03-2021 05:17 PM
Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! Mike@CZP Brakes, Suspension, Chassis 348 06-01-2018 12:29 PM
Winmax USA Brake Pads - Street, Autocross, Track, Endurance! CSG David Suspension | Chassis | Brakes -- Sponsored by 949 Racing 65 07-04-2016 09:59 AM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 01:45 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
