Old 05-04-2016, 06:21 PM   #1
MechOps
Drives: 2013 BRZ Limited
Cracked Tail light
Hey guys,
Got about an inch and a half of cracking on my stock tail lights. What would be the best way to fix it? Just searching around, I suppose a common fix is to use an epoxy?
Thanks.
MechOps is offline   Reply With Quote
Old 05-04-2016, 06:26 PM   #2
8R6
8R6's Avatar
Drives: FRS
wheres the crack at? i personally would rather just buy another set of taillights from someone selling their stock ones. dealing with condensation issues would bug the hell out of me
8R6 is offline   Reply With Quote
Old 05-04-2016, 07:40 PM   #3
MechOps
Here's the crack. The crack starts at the bottom.
I want to try to save the light, but if not, I'll get another one.
https://drive.google.com/open?id=0B6...jVlNE9EZUhxb0E
Old 05-04-2016, 09:16 PM   #4
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
Personally I wouldn't worry about it until it gets worse, then it gives you an excuse to upgrade.
Clueless
YamahaR86 is offline   Reply With Quote
Old 05-04-2016, 09:24 PM   #5
headlikeahole
headlikeahole's Avatar
Drives: Ultramarine toyobaru
I wish my tails had a crack like yours so all the water would drain out.
headlikeahole is offline   Reply With Quote
Old 05-04-2016, 10:00 PM   #6
MechOps
Lol. Try drilling a tiny hole at the bottom
Old 05-04-2016, 10:46 PM   #7
MrMarinakos
Drives: Asphalt Monogram Fr-s
Sell you my stock tails for 105$ shipped.. lol
MrMarinakos is offline   Reply With Quote
Old 05-04-2016, 10:48 PM   #8
MechOps
Lol. That's actually not a bad idea.
Old 05-05-2016, 12:13 AM   #9
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
I've had a cracked tail light (also at the bottom, but waaay worse) for over a year now, probably like 3-4k miles. Light still works fine. I'm leaving it alone till I buy Toms lol.
PandaSPUR is offline   Reply With Quote
Old 05-05-2016, 06:47 AM   #10
MechOps
I'd assume condensation/water problems are worse?
Old 05-05-2016, 07:02 AM   #11
RichardsFRS
RichardsFRS's Avatar
Drives: 2013 Pearl White 6MT
I'd run a bead of clear caulk right thru it and leave it, till it becomes a bigger problem. Don't want water in there
Back from bancation in Banopolis where I laid on the beach with a beer between my legs. I at night and ate at sun rise
RichardsFRS is offline   Reply With Quote
Old 05-05-2016, 07:49 AM   #12
MechOps
Indeed. I don't want to leave it the way it is and have bigger problems down the road. I can caulk it or put some kind of a clear epoxy to mitigate any creeping.
Old 05-05-2016, 09:41 AM   #13
PandaSPUR
PandaSPUR's Avatar
Not really. The hole crack is at the bottom, so its not like water can flow in and fill the housing. Plus, any condensation just leaves through the hole lol.
Old 05-05-2016, 10:22 AM   #14
I would just leave it alone. Like has been said there isn't much that is going to get in there and if it does it can get right back out again. Any patch job is going to look worse than the crack.
Valenti Bumper Light $179.99 Tail Light $299.99 Fog Light Kit $90.99 nigel-jdmparts Exterior Parts - Lighting 14 06-23-2015 06:32 AM
FS: Cracked OEM Tail Lights klittl06 Exterior Parts (Aero, Lighting, Etc.) 2 10-12-2013 01:00 AM
For Sale: Cracked but functional stock tail lights. enjoi23 Exterior Parts (Aero, Lighting, Etc.) 5 07-07-2013 04:11 PM
FS: Stock tail lights-Passenger side cracked continuecrushing Exterior Parts (Aero, Lighting, Etc.) 0 06-28-2013 01:55 AM
