Old 05-04-2016, 03:26 PM   #1
j.boy
Drives: GT86
Trouble updating OpenFlash Manager to 1.25.1
Need help, I did all i could to fix it but i still cant update my OpenFlash Manager, now i cant access my OFT thru OFM. (cant data log, cant add new OTS, nor anything)
with error access to path 'C:\OpenFlash\OpenFlash Manager.exe' is denied
Im using windows 7.
j.boy is offline   Reply With Quote
Old 05-04-2016, 09:18 PM   #2
steve99
Im using windows 7.
Log in as administrator, go to the c:\openflash directory and delete everything in it including the directory iself.
go to openflash.com downloads and download the latest ofm software and install, make sure your administrator , should be good
plug in oft and let it update while connected to internet
j.boy (05-05-2016)
Old 05-05-2016, 11:09 AM   #3
j.boy
Drives: GT86
Thanks steve.. I was already using an administrator account but still popping error upon update...
I tried opening the PWGPro application which made the tablet do some upgrade and including the firmware. then afterwards i opened the OFM application and the update went well. For those other users having trouble with the update, try doing what i did hopefully it will get fixed too.
Old 10-16-2018, 01:51 AM   #4
lorein0688
Drives: Fastcar
Well, it might happen the PC/laptop drivers are not updated so update them as it is found that the problem is related to the outdated drivers. Apart from that run the SFC scan, this helps you to repair the corrupted system files just by scanning once.
To update the drivers easily make use of the driver Booster to update them automatically
http://www.fixwindowserrors.biz/blog...driver-booster
lorein0688 is offline   Reply With Quote
OpenFlash Tablet will not connect to OpenFlash Manager rever5e Software Tuning 10 03-12-2022 10:17 AM
Quick question openflash manager and flash tablet manager Nisien Software Tuning 3 02-28-2016 03:08 PM
OpenFlash Manager 1.07.1 Mad_Hatter Software Tuning 24 04-24-2014 06:46 AM
Now Available: OpenFlash Manager 1.04 Shiv@Openflash Software Tuning 37 12-14-2013 10:02 PM
