| Northern California NorCal |
Drives: 2013 White-Out FRS
Oil Leak - Where to Warranty?
Delete.
I live my life one quarter-pounder at a time.
Drives: Asphalt 2014 FRS
I've had surprisingly good experiences with Stevens Creek Toyota although I've never done anything warranty related there. Good luck!
Drives: Scion FRS RS 1.0 2015
If you look from the engine bay, do you see oil on the under cover? If the timing cover is leaking bad, you should be able to see oil around the timing cover specially the bottom part. If not, something else is leaking. Possibly oil pan or the oil pan drain plug.
Front engine Rear wheel drive Supercharged |
I have same leak, corner of valve cover and timing cover. From what I heard, engine must come out to fix that leak. How many miles do u have? Also is this on the driver side?
#5 | |
57k miles, but had it since like 30k.
Grip>Drift
Drives: FRS
Try going to a local Toyota dealer with a much larger service department. Try Piercey in Milpitas, they have the biggest service department I can think of near the South Bay.
| Slow leak on tires under warranty | SmartedPanda | Issues | Warranty | Recalls / TSB | 10 | 12-28-2015 09:31 PM |
| Yet another oil leak.... | Astroboy | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 09-24-2015 01:02 AM |
| Help - oil leak | tlim | Engine, Exhaust, Transmission | 4 | 04-10-2015 08:40 AM |
| Warranty Work With Mods + Extended Warranty | Wyattkb | Issues | Warranty | Recalls / TSB | 3 | 01-20-2015 04:23 PM |
| A/T Pan leak | goke186 | Issues | Warranty | Recalls / TSB | 0 | 04-15-2013 10:31 PM |
