Old 04-28-2016, 09:56 AM   #1
hamzam
Proud dad of 2 boys :)
hamzam's Avatar
Drives: Firestorm 6-MT
Talking Difflow Diffuser
So, a long, long time ago, in this very galaxy, I saw this diffuser on an FR-S, one of the first ones to be showcased at SEMA.
After some research, found out it's not a custom diffuser... but made by Difflow.
The one above is made to fit Lotus Elise's. They make products for the ZN6/ZC6 as well, similar to Driveway Labs / Velox, but that's not what I was going for.
There's a bigger version available for the Elise... So that got me thinking.
From what I understand, to increase downforce, you can add a big ol' wing to add drag (decreasing speed of air on top of vehicle) or you can speed up the air underneath the car for the same effect.
I still have to raise the back of the diffuser up about 1", so it's not angled slightly down towards the back of the car. This involves cutting the bottom of the rear body panel. I'll do that next week.
It WORKS, though you have to be at speed .
There is no rear end hop anymore going over bumps. The car is GLUED to the pavement. Now the car feels like it CARVES a turn instead of drifting side to side (again, at speed. we're talking triple digits in Mexico).
There is just so much more grip available in the back, and this balances out all the aero in the front.
Very, VERY happy with the results. And it don't look to bad either
hamzam is offline   Reply With Quote
Old 04-28-2016, 09:59 AM   #2
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
It looks really tucked up there. Any more pictures from under the car?
Also the Products they sell for the Twins are Drivewaylabs Diffusers.
DustinS is offline   Reply With Quote
Old 04-28-2016, 10:52 AM   #3
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Looks pretty good and I applaud you for doing something different!
Instagram: trevor.parque
Old 04-28-2016, 11:25 AM   #4
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
Good job
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline   Reply With Quote
Old 04-28-2016, 12:32 PM   #5
hamzam
hamzam's Avatar
Here's diffuser as I got it:
Only modification I did:
Don't mind my exhaust, was one of my first mods 3 years ago, lol... Greddy RS on order.
Old 04-28-2016, 01:58 PM   #6
DustinS
DustinS's Avatar
Just a friendly tip. Moving the Front of the diffuser down even with the bottom of the Subframe should make it work better. You also really want the exhaust to go above the diffuser. Pretty much making the diffuser pointless with the exhaust disrupting the air you are trying to smooth out.
Old 04-28-2016, 02:05 PM   #7
OkieSnuffBox
Drives: '23 BRZ Limited
I also don't get the hard angle change vs a slow radius.
Seems as though that would cause flow separation reducing the effectiveness of the diffuser.
Old 04-28-2016, 02:07 PM   #8
8R6
8R6's Avatar
Drives: FRS
i looked into Difflow exige diffuser awhile back also (they've been around for a bit). as legit as their diffusers are, when custom fabbing the exige part to fit our frs/brz, i feel like that is more of a show piece than functional piece... especially if you're mounting it above the exhaust.
i have the driveway labs diffuser (which is exactly what difflow sells for the twins anyway) and it's awesome and functional. it tucks right under the muffler and piping and level with the bottom of the car. and you can notice the effects even at legal hwy speeds. just cruising at 60mph on a sweeping turn on a fwy, the rear end is planted to the road. stability increases even more when driving even faster (in mexico).
8R6 is offline   Reply With Quote
Old 04-28-2016, 02:53 PM   #9
hamzam
hamzam's Avatar
I know the feeling. Sadly, nothing I can do about the exhaust location, and I rather like it up top
As for functionality, I too went to Mexico last night. It works. I will bet my car. I hit about 115, and my God... at those speeds, you usually "sway" over when you take a turn.
Now I carve turns no problem. Rear end is planted, NO hops at all going over bumps on the highway. Car feels tight all around. I do have front aero as well, so that helps. But before this, car was pretty sloppy at high speeds, with front planted, and rear just hanging on.
I can't believe how much a difference it made.
I do appreciate your input!
Old 04-28-2016, 05:04 PM   #10
NahumCC
Drives: 2013 FR-S 10 Series
Or just get creative and make a blown diffuser like the ones that got banned from F1
NahumCC is offline   Reply With Quote
Old 04-28-2016, 08:22 PM   #11
Gunman
Drives: 2019 Mazda Miata RF
And a special tune to take care of the throttle affecting the aero...
Gunman is offline   Reply With Quote
Old 04-28-2016, 08:36 PM   #12
NahumCC
Why not....ECUTEK let's you have multiple maps....or take what @VitViper was showing with motec but dial in some valve overlap and fuel on the exhaust stroke based on yaw rate.
Sent from my SAMSUNG-SM-G870A using Tapatalk
Old 04-28-2016, 09:49 PM   #13
hamzam
hamzam's Avatar
Totally understand what you and Dustin are saying.
Essentially, I'd have to relocate my exhaust if I mounted it lower on the subframe, (almost level with the bottom of the control arms). That, or cut the diffuser, which I'm not willing to do or it'd all go to waste :p .
I can't sacrifice trunk space or cut any holes in the chassis as its my daily, and I love cruising in it with the fam, so it's got to be somewhat muffled/civilized/usable.
But, my number one excuse is I'm broke AF (well, used up my car parts budget) and this is last mod of the year
It works great, I wish I was at Lime Rock this Saturday for the time attack event, but I'm helping my sister move to New Jersey.
Damn you, dirty Jersey.
Diffuser Add On? MisterSheep Cosmetic Modification (Interior/Exterior/Lighting) 16 11-24-2015 04:51 PM
TRD diffuser aznatama Cosmetic Modification (Interior/Exterior/Lighting) 3 01-05-2015 12:55 PM
WTB OE Diffuser skyloran Exterior Parts (Aero, Lighting, Etc.) 0 06-25-2014 02:33 PM
OEM Diffuser Bg8780 Cosmetic Modification (Interior/Exterior/Lighting) 3 03-10-2014 10:18 AM
Where to buy brz diffuser? DarkCard Cosmetic Modification (Interior/Exterior/Lighting) 9 11-09-2012 12:18 PM
