Old 04-27-2016, 03:54 PM   #1
BFIFE22
BFIFE22's Avatar
Drives: 2013 GBS BRZ Limited
Is this puncture repairable?
Noticed I had a screw in my rear tire earlier, but I haven't had one this close to the edge of the tire. I was wondering if anyone else has had a puncture in a similar location before, and if it was able to be patched or not? I have an appointment to get it looked at in a few hours but just wanted to know what to expect beforehand
APEXi / JDL / Perrin / Grimmspeed / Tein / Hotchkis / TRD / RAYS / Michelin / Raceseng / JPM Coachworks / SWEIDIT / Carsmo / TOM's / OFT / OEM Audio
BFIFE22 is offline   Reply With Quote
Old 04-27-2016, 04:27 PM   #2
Nope. Way too close to the sidewall. If you find somebody that says they can fix it don't trust them ever again. That would be a blowout waiting to happen even if repaired.
grinerizer (04-29-2016), mixtape (04-28-2016), pfaffendorn (04-27-2016), rookie (04-27-2016)
Old 04-27-2016, 04:46 PM   #3
BFIFE22
BFIFE22's Avatar
That's what I figured after doing some reading. Awesome .
Am I ok to drive 3 miles to work and back for the next 2 days? No one near me carries PSS in my size, but I'll be able to get one on Monday. Luckily Tire Rack will be able to reimburse me for the replacement
Old 04-27-2016, 04:50 PM   #4
Ya that should be fine. Just don't go too fast or start drifting around corners. The hole won't cause you much issue unless you hit extreme temperatures. Too hot or cold and just a bit of sidewall loading will split that thing in half starting at the patch.
Old 04-27-2016, 05:02 PM   #5
pfaffendorn
pfaffendorn's Avatar
Drives: 2014 ssm BRZ Limited 6M
I concur, if only because I would prefer to bite the bullet and replace the tire rather than worry about it until I landed in a ditch. I am guessing, but the reasonable explanation seems to be that your repair would tend to flex with the sidewall, leading to an inevitable failure. A repair in middle of the tread would flex much less, and stay solid and safe.
Your safety and peace of mind must be worth $100 or so, right?
There are worse things to worry over.
pfaffendorn is offline   Reply With Quote
The Following User Says Thank You to pfaffendorn For This Useful Post:
turtlefeeder (04-28-2016)
Old 04-27-2016, 08:22 PM   #6
ls1ac
ls1ac's Avatar
As said a mushroom plug RTVed from the inside will let you drive for a short while safely, it will not fail catastrophically but will lose air over time. Turns stops and hard starts are the enemy.
Old 04-28-2016, 04:27 PM   #7
turtlefeeder
turtlefeeder's Avatar
Drives: UltraMFrS
totally agree with @pfaffendorn
safety over all. could lead to other wrecks if you happen to forget about that spot.. change tire worth saving your life or other's
turtlefeeder is offline   Reply With Quote
Old 04-28-2016, 04:59 PM   #8
BFIFE22
BFIFE22's Avatar
The Tire Rack warranty service is going to cover the replacement, but it's not going to be here for another week. My commute to work is literally 6 minutes so I'll just drive slow and only to work and back until then. Apparently the PSS is a hard tire to get right now :/
Old 04-28-2016, 11:30 PM   #9
DavidGaddy
Drives: 2007 Lexus IS250 2013 Brz WRB
I had a nail on the sidewall of a tire and I dove on that tire for months just get the tire plugged
DavidGaddy is offline   Reply With Quote
Old 04-29-2016, 01:42 AM   #10
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Because they're being phased out! #illuminati
N1rve
The Following User Says Thank You to N1rve For This Useful Post:
ZionsWrath (04-29-2016)
Old 04-29-2016, 09:17 AM   #11
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
please tell me that's a lie... I have a new one sitting at home from insurance and can't afford to buy more atm
fumanchu1 is offline   Reply With Quote
Old 04-29-2016, 09:23 AM   #12
ZionsWrath
Thanks
ZionsWrath's Avatar
What is more illuminati about is they are phasing out before new tire is launched so people buy them!!!
Replacement is the Pilot Sport 4, for those who didn't know
Old 04-29-2016, 10:23 AM   #13
ARTBRZ
Aloha!
ARTBRZ's Avatar
I was a little worried there for a moment. Is there any sites that tell us the difference between the two (specs)?
ARTBRZ is offline   Reply With Quote
Old 04-29-2016, 11:08 AM   #14
extrashaky
Drives: 2014 BRZ Limited
Well, that's a dipshit way of doing it. If the PSS is out of stock and the PS4 isn't out yet, those of us who need tires now will end up buying another brand instead.
Bent RFP1 repairable? antoic Tracking / Autocross / HPDE / Drifting 21 03-15-2017 10:01 PM
Tire puncture.. SD County Dustn1Frs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 07-17-2014 01:41 PM
Tire Puncture! What should I do? KevinTJH Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 05-12-2014 07:47 AM
Tire Puncture Euro7R Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 03-28-2014 03:05 AM
Curbed my rim...repairable? jermyzy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 04-29-2013 05:05 AM
