Old 04-25-2016, 08:26 PM   #1
aquaman
aquaman's Avatar
8psi Wastegate actuator length AVO Kit
So crazy question... Has anyone messed with the length of the 8psi wastgate actuator (lengtherning or shortening) to get a little more boost retention. I have a perrin EBCS which should allow me to run up to 12 psi with the 8 psi wastegate. I'm only getting peak just shy of 10psi. If so what have you found a good length? If no one has, what is the length of the wastegate from AVO? thanks for the help.
aquaman is offline   Reply With Quote
TOMEI HEADERS EXPREME UNEQUAL LENGTH / EQUAL LENGTH AND JOINT PIPE FOR FRS/BRZ myjdmparts Groupbuys 85 10-07-2015 03:17 PM
Clutch actuator position? Kiske Engine, Exhaust, Transmission 1 03-27-2015 06:43 PM
FS: [NSW] GT86 AVO Turbo Eflex 228KWs@wheels 8psi yenvy4 Australia Classifieds 0 09-25-2014 02:38 AM
?equal length or unequal length headers? subaruferrucci Engine, Exhaust, Transmission 22 07-11-2013 01:56 AM
