Old 04-20-2016, 05:14 PM   #1
Abe1120
Drives: 2015 scion frs
Frs possibly burning oil
I recently noticed that slowly my 2015 frs is loosing oil. I check the dip stick around once a week since I do honestly drive the car whenever I can maybe 50 to 150 miles daily and that is also hard driven but Rev limiter is never hit. I'm running a custom etune from shiv for stage 2 uel e85 and it's been about a month or 2 and the car runs great. I installed a perrin oil cooler also when I was getting the tuning done. Maybe the oil could be a little low since it may sit in the cooler? But I'm not sure how it works 100%. But today I also installed a single Radium oil catch can. I went out for a drive and I drove how I would normally drive I got home and when I went to check the dipstick there was no oil on it but a little smoke was coming out of the hole for the dipstick any ideas? Thanks for the help
Sent from my SAMSUNG-SM-G930A using Tapatalk
Abe1120 is offline   Reply With Quote
Old 04-20-2016, 05:17 PM   #2
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Did you add any oil when you added the oil cooler?
jawn is offline   Reply With Quote
Old 04-20-2016, 05:19 PM   #3
Abe1120
Yes I added the extra quart
Old 04-20-2016, 07:37 PM   #4
humfrz
Originally Posted by Abe1120 View Post
I recently noticed that slowly my 2015 frs is loosing oil. any ideas? Thanks for the help
I'd suggest you park it on the flat ......then check the oil level again. If it's low, add oil up to the full line. Drive it for a few miles, let it sit and check the oil level again.
The engine just may be confused as to where the "new full" line is .....
humfrz
PS - if your car is "burning" that much oil ........ there will be no doubt if you look at/smell the exhaust when it's running ........
new2subaru (04-20-2016)
Old 04-21-2016, 03:34 AM   #5
Abe1120
Yeah I never smell anything or see any smoke anywhere could be the type of oil I'm running combined with e85 is just rough on it.
Old 04-21-2016, 03:44 AM   #6
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
With e85 in use regularly, you should cut your oil change intervals in half to stop fuel dilution honestly but that's besides the point. Is the front timing cover leaking oil? This usually manifests itself as black grime above the header. Also are the catch cans full of oil? Did you check the entire oil cooler, including the line, sandwich plate, and mocal radiator core?
Also if my memory is correct, the perrin cooler is thermostatic check and make sure at cold temps that the oil level is a bit over the fill line, then start the car and allow to warm up to circulate the oil through the cooler at the temp, I have a feeling the oil that remains in the cooler is marginal if not a slow trickle
Old 04-21-2016, 03:47 AM   #7
Abe1120
I'm 100%ive got no leaks anywhere the header is clean and so is the skid plate. I do change my oil about every 3k miles but I've been using Mobil 1 and someone told me it's not the best going to be trying motul to see if e85 is going to be as rough as it is.
Old 04-21-2016, 03:59 AM   #8
FRSBRZGT86FAN
Also according to the installation manual for the perrin oil cooler here:
http://perrinperformance.com/attachment/178266-.pdf
When you do an oil change:
Start your car like normal and let it run for 10 seconds, then shut engine off. Heavily inspect all oil lines and connections for leaks. If no leaks are found, add your additional QT of oil at this time.
That means the a car with the perrin oil cooler should use 6.4 liters of oil not 5.4 liters as is normally the case. Next oil change make sure 6.4 liters is added then watch it like a hawk, the only other issue I can think of is the motor is burning it up.
Old 04-21-2016, 04:00 AM   #9
Abe1120
Hopefully it isn't the motor burning it up but I'll order the oil soon and get it changed up and see from there
Old 04-21-2016, 04:37 AM   #10
ZionsWrath
Thanks
ZionsWrath's Avatar
Take the tray off and look for oil leaks.
Old 04-21-2016, 05:49 AM   #11
As Hum said if you are burning that much oil that quickly you are going to have a big grey cloud following you everyplace you go. There will be NO doubt that you are burning oil.
There is leak someplace that you just have not found yet or you didn't have enough in there in the first place.
humfrz (04-21-2016), ZionsWrath (04-21-2016)
Old 04-21-2016, 06:09 AM   #12
Abe1120
Definetly isn't the front timing cover and I never see thick clouds of smoke and I've also never smelled oil burning. I'll get the car jacked up after work and I will check it out from underneath.
The Following User Says Thank You to Abe1120 For This Useful Post:
Tcoat (04-21-2016)
Old 04-21-2016, 05:50 PM   #13
Abe1120
I removed the skid plate and checked underneath the engine I don't see anything that looks to be oil coming out of anywhere and the skid plate is clean.
Old 04-21-2016, 07:22 PM   #14
humfrz
So, @Abe1120 ...... did you do what I suggested .. ??
humfrz
Burning Oil? RandomHero Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 25 10-04-2019 04:56 PM
Burning smell Riftur Engine, Exhaust, Transmission 9 04-13-2016 01:50 AM
Burning smell PLease help! Chase1996 Issues | Warranty | Recalls / TSB 62 11-02-2015 01:11 PM
Something Burning? samisons Issues | Warranty | Recalls / TSB 8 11-27-2013 10:18 PM
Burning oil? N/A Synack Issues | Warranty | Recalls / TSB 11 11-08-2012 06:14 PM
