Old 11-26-2013, 02:25 PM   #1
samisons
Drives: 2013 Raven Fr-s, 2013 Versa Sedan
Something Burning?
Months after getting my fr-s the car has started to grind into 2nd and 3rd Today after needing air in my tires I went to the service department at my local toyota dealership. Bottom line the car has a Burning smell almost like a clutch is going out, but the Stealership employee told me they couldn't do anything about a transmission for months now due to back orders on the transmissions.
Should I go to another dealership and have them diagnose the problems I'm having or am I just going to have to wait until something breaks?
And before anyone says it's me burning the clutch I've been driving manual for over 10 years and for the almost 450K total Miles I've logged on my last 3 cars that were manual I've only had to replace one clutch on my G35 after 115k and I bought that car used knowing the clutch was going to need to be replaced.
samisons is offline   Reply With Quote
Old 11-26-2013, 02:56 PM   #2
BaeK
BaeK's Avatar
Drives: 2013 Whiteout FRS
Doesn't hurt to stop by at a different dealer. Better safe than sorry!
BaeK is offline   Reply With Quote
Old 11-26-2013, 03:20 PM   #3
humfrz
Originally Posted by samisons View Post
Months after getting my fr-s the car has started to grind into 2nd and 3rd .......... Bottom line the car has a Burning smell almost like a clutch is going out,
..........Should I go to another dealership and have them diagnose the problems I'm having or am I just going to have to wait until something breaks?.......
Well, just rev that puppy up to about 6,000 rpms and dump the clutch ..... then you will know .....
Seriously, you may consider warming up the engine, set the e-brake, put it in 2nd gear, rev the engine to about 2,500 rpm, let the clutch out slowly to see if it will stall the engine. That is an old school test for a warn clutch.
Also, you may wish to check the clutch/brake fluid resevoir to make sure it's topped off.
Then you could bleed the clutch line to rid it of any air.
Then you could adjust the clutch.
Or, just take it down to your local auto shop, come home, take a nap and have them "fix" it ...
humfrz
Old 11-26-2013, 04:09 PM   #4
samisons
Well, just rev that puppy up to about 6,000 rpms and dump the clutch ..... then you will know ..... humfrz
I'm not sure I would feel comfortable doing that =p.
I'm just in shock at how many issues this car has had with under 4k miles.
I've had better luck with 80s Nissan's don't get me wrong I love this car, but no way even in the first year should a car have this many issues.
for the input though.
Old 11-27-2013, 02:29 PM   #5
frs23
frs23's Avatar
Drives: FR-S H Lava
Its not burning oil smell?
http://www.ft86club.com/forums/showthread.php?t=45097
frs23 is offline   Reply With Quote
Old 11-27-2013, 04:45 PM   #6
samisons
Originally Posted by frs23 View Post
It's possible I took it to another Toyota dealership this afternoon and the Mechanic told me they put some kind of coating on the power train that may cause that smell otherwise they told me to just come back if the problem worsens Also to answer your question it doesn't smell like oil to me..
Old 11-27-2013, 08:47 PM   #7
samisons
OMG that was the problem!!!
Old 11-27-2013, 09:35 PM   #8
humfrz
humfrz
Old 11-27-2013, 10:18 PM   #9
samisons
Oil coming out of that blocker
Sent from my SCH-I545 using Tapatalk
Burning Oil? RandomHero Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 25 10-04-2019 04:56 PM
Weird Burning Smell? t00n3wb Issues | Warranty | Recalls / TSB 27 05-21-2018 03:58 PM
Anyone smell burning outside the car? DarrenDriven Scion FR-S / Toyota 86 GT86 General Forum 115 01-13-2015 01:31 AM
Burning smell Boofneenee Issues | Warranty | Recalls / TSB 6 09-30-2013 06:28 PM
Burning oil? N/A Synack Issues | Warranty | Recalls / TSB 11 11-08-2012 06:14 PM
