btr.life
Drives: 2022 GR86
Sparco seat base fitment issue?
Reposting this here as probably more experience than genera forum.
I received my Sparco seat base and went to test fit it before assembling with the side mounts and sliders. It seems a bit weird to me as it does not sit level in the car. The rear is much lower than the front and the front mount hole/flange does not sit flush with the floor either. Is that normal for these? I am pretty sure the Sparco mounts in my BMW are level when installed in the car. These just seem odd because nothing is flush with the mounting surface and if I go to bolt it down there will be a small gap between the floor and mount flange.
I have seen some brackets come in the shop with a slight rake to them, but to be honest I would contact Sparco to be sure. I've had some Sparco brackets come in before with poor fitment. They're good to deal with though, but they may tell you that you have to handle it with the company you ordered through.
#3 | |
btr.life
Drives: 2022 GR86
It is probably just normal for this mount in this car.
#4 | |
#5 | |
btr.life
Drives: 2022 GR86
This car is just not what I was used to and that is what I was trying to figure out. Sounds like it is supposed to be raked back in this car. I'll be bolting the seat in soon
Drives: '13 Firestorm FRS
I can't see your pictures but I use a Planted bracket for my Sparco seat. It does have a slight rake to it, which threw me off at first, but everything mounted perfectly.
| SPARCO PROADV SEAT INSTALLED IN BRZ | Racecomp Engineering | Tracking / Autocross / HPDE / Drifting | 57 | 02-11-2019 02:41 PM |
| Sparco seat base fitment? | justinco | BRZ First-Gen (2012+) — General Topics | 2 | 04-19-2016 10:52 PM |
| WTB Planted Seat Base | Cjymiller | Want-To-Buy Requests | 5 | 07-28-2015 12:43 PM |
| FS: Sparco driver side seat base + rails and bolts for free | BRZ'13 | Canada Classifieds | 9 | 07-11-2015 08:56 AM |
| FS: Sparco seat bases, rails, and side mounts | pleong | Interior Parts (Incl. Lighting) | 4 | 03-06-2015 09:41 AM |
