Old 04-19-2016, 01:26 AM   #1
justinco
justinco's Avatar
Drives: 2022 GR86
Sparco seat base fitment?
I received my Sparco seat base and went to test fit it before assembling with the side mounts and sliders. It seems a bit weird to me as it does not sit level in the car. The rear is much lower than the front and the front mount hole/flange does not sit flush with the floor either.
Is that normal for these? I am pretty sure the Sparco mounts in my BMW are level when installed in the car. These just seem odd because nothing is flush with the mounting surface and if I go to bolt it down there will be a small gap between the floor and mount flange.
justinco is offline   Reply With Quote
Old 04-19-2016, 09:26 PM   #2
atlbrz
Drives: Hyper Blue BRZ
I bit of pretty sure the Sparco is made by Planted Technologies. I have mounted several seats using Planted and other seat bases in cars, but not the BRZ/FRS. I have never expected the seat base to be level. They have all had a little of rake to them. Of course you said a lot lower in the rear. You should be able to compensate some with the side mount holes. I am a bit surprised the holes don't line up. I have had to enlarge/adjust holes on some of my cars.
atlbrz is offline   Reply With Quote
Old 04-19-2016, 10:52 PM   #3
justinco
justinco's Avatar
Drives: 2022 GR86
Thanks. So it sounds like the base being raked back is just normal. The holes all line up OK, so I think it is fine and I am just being paranoid.
SPARCO PROADV SEAT INSTALLED IN BRZ Racecomp Engineering Tracking / Autocross / HPDE / Drifting 57 02-11-2019 02:41 PM
FS: Bride Reclining Seat Base Model - New byun Interior Parts (Incl. Lighting) 14 06-24-2016 11:45 AM
WTB Planted Seat Base Cjymiller Want-To-Buy Requests 5 07-28-2015 12:43 PM
FS: Sparco driver side seat base + rails and bolts for free BRZ'13 Canada Classifieds 9 07-11-2015 08:56 AM
FS: Sparco seat bases, rails, and side mounts pleong Interior Parts (Incl. Lighting) 4 03-06-2015 09:41 AM
