Old 04-19-2016, 10:30 AM   #1
itsAlex
itsAlex's Avatar
Drives: 2016 4Runner / 2016 FR-S
Placebo Effect | Warmer weather = better overall experience
This is just a mere observation of mine, nothing important or scientifically proven, just thought I'd share
I've only owned the FRS for about 2 months now, and we've been getting weirdly warm weather down here in the GTA for the past two days (20C and up).
Driving the car in the past 2 days has been way more fun than driving it in colder weather in the past month. I haven't adjusted my clutch height yet, but my shifts have seemed to become more smooth most of the time. The shifter itself glides into each gear buttery smooth, in fact I don't have to warm up the transmission in order to get smooth shifts. The engine also seems so much smoother, I don't know why!
Even the noise of the intake seems more refined, can this all be due to warm weather? I feel like this is just me encountering a serious case of the placebo effect, but I know there are subtle differences, I know I can't be tripping out this much.
For those who drive this car in the cold and warm weather, do you experience the same thing? Or is it just me?
I pay more per month for insurance than I pay for the FRS.
itsAlex is offline   Reply With Quote
Old 04-19-2016, 10:38 AM   #2
mazeroni
Drives: 2013 Scion FR-S Series 10
Yup. When the temps are below 70 it feels like you have to manhandle all the inputs to keep things smooth. Granted I have the stock transmission fluid. Over 70, 1>2 super smooth and the rest of the gears just seem to work so much better. The clutch and gas feel easier to modulate too. I find that is true even after a long drive in cold weather. The car just does not like cold weather.
This also being an invitation to 'hoon-the-shit' out of the car.
mazeroni is offline   Reply With Quote
Old 04-19-2016, 10:38 AM   #3
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Well for one your transmission could be smoother due to the fact that the fluid is warmer which helps guide the trans into gear better and will result in smoother shifts.
Instagram: trevor.parque
Old 04-19-2016, 11:16 AM   #4
Once the car is warmed up I feel no difference in a thing no matter what the temperature is outside.
Old 04-19-2016, 11:35 AM   #5
JimR
JimR's Avatar
Drives: '15 FR-S, '92 Sentra SE-R
Bushings, door seals, engine mounts, diff mounts, and really anything with compliance is likely affected by extreme cold. Back during a bad cold snap, my all-seasons would flat spot from sitting overnight and thump for a few blocks. With fluids and rubber closer to operating temperature at ambient, no doubt the cumulative effect makes for a nicer drive.
JimR is offline   Reply With Quote
Old 04-19-2016, 11:46 AM   #6
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
this sounds like one of the positive effects of global warming.
Assuming you believe the hype, of course.
Old 04-19-2016, 11:58 AM   #7
Braces
Braces's Avatar
Drives: 17 Alfa Romeo 4C
I had the opposite feeling in 100 degree F Arizona. Summers .... I ran the A/C all the time which robbed some of the power. Winters ... no A/C needed .... car was way more responsive.
My 2013 Firestorm Red 13 FRS is gone. Bought the next best thing: 2017 Alfa Romeo 4C
Braces is offline   Reply With Quote
Old 04-19-2016, 12:10 PM   #8
Old 04-19-2016, 12:11 PM   #9
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
I've posted my fastest lap times in the winter...
Old 04-19-2016, 12:15 PM   #10
Not sure some of you know what "winter" means!
Old 04-19-2016, 12:29 PM   #11
mav1178
mav1178's Avatar
Oh well, everyone hates California.
I'll just enjoy my 60-70F winters. And zero humidity in the summer.
Old 04-19-2016, 02:07 PM   #12
Weigaldo
Weigaldo's Avatar
Drives: 2016 Steel AT FRS
I was debating making a post about exactly this. I've had my car since November, and only recently have we been seeing above 70 here in Chicago. I had zero confidence in the cold because the TC would kick in so often at the slightest input. Above 70, I can actually take turns quicker and power out of them without sliding. This car has so much more grip above 70 with the all-seasons, I can't imagine how sticky it gets with good tires.
Weigaldo is offline   Reply With Quote
Old 04-19-2016, 02:26 PM   #13
"All seasons" should be called 3 seasons. They still get hard in the really cold weather.
Old 04-19-2016, 06:34 PM   #14
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
Lower temps, like lower altitude improve performance.
At lower temps, air is more dense. Greater air density means an increased intake A/F mass. Its like environmental supercharging. On my MR2 turbo the ECU would lock into low boost mode when intake air temps were below 32F to protect the engine from the combined effects of high boost plus increased air density.
It's the same principle behind lost performance at high altitudes. High altitudes mean lower atmospheric pressure, hence less A/F charge density.
billwot is offline   Reply With Quote
FS: Weather Tech All Weather Floor Mats J. Fernandez Interior Parts (Incl. Lighting) 2 07-29-2015 12:24 AM
Hawaii weather/warmer weather 5w30 oil keonigt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 06-11-2015 08:50 PM
Which oil weight for warmer climates Don Ivey Engine, Exhaust, Transmission 5 03-16-2015 01:12 AM
Subaru USA's New 2015 BRZ Series Blue with STI Parts has a Placebo Effect…. vh_supra26 BRZ First-Gen (2012+) — General Topics 393 07-30-2014 12:27 AM
Warmer switch backs to match DRLs TheBatman Cosmetic Modification (Interior/Exterior/Lighting) 0 07-26-2013 07:58 PM
