Old 04-16-2016, 03:47 PM   #1
mhiscott
Drives: 2013 FRS
Best way to pick up water lines for turbocharger
So I'm replacing my Precision 4854 (oil cooled only) with a Garrett GTX2867r. The Garrett will need a filter and restrictor in the oil feed line, but also I will need to add water lines to the mix.
Where is the best spot to pickup the water feed and return on this car? Seems you can get feed from a plugged hole in the engine, and buy an oem subaru part for the return (from forester xt). Is this the best bet, or should I pick it up at the throttle body?
Thoughts??
mhiscott is offline   Reply With Quote
Old 04-16-2016, 03:58 PM   #2
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
You can look at the fullblown install guide and tap into the lines on the throttle body.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 04-16-2016, 07:30 PM   #3
mhiscott
Drives: 2013 FRS
I wasn't able to find the fullblown manual but it seems jdl and avo use the tb lines and leave the tb unhooked. Not sure I'd want to remove that functionality living in a cold climate.
http://www.ft86club.com/forums/showthread.php?t=50427
Am I right in thinking I could buy the forester xt pipe in the link above, and basically use the two connections (block and return added to the new fxt pipe) as feed/return? Leaving my tb as is?
Old 04-16-2016, 08:10 PM   #4
GsxrMe
GsxrMe's Avatar
It'll be ok, the turbo will be more than happy to introduce extra heat into your intake.
2014 Subaru BRZ
AVO Turboworld Turbocharger Kit AVOturboworld Forced Induction 11 08-05-2015 11:17 PM
Turbocharger in St. Louis Vinsanity091 Rocky Mountains / Great Plains 0 01-13-2015 11:49 PM
Turbo coolant lines GTX2867. Can I use the throttle body coolant lines? mike the snake Forced Induction 8 04-01-2014 05:56 PM
Electric Turbocharger Shankenstein Forced Induction 91 06-24-2013 02:47 PM
