Mad Sciontist
Drives: gt86
GRD turbo system
Hi guys,
Im currently designing a turbo system for the 86 running a GTX3071R with a .63 Tial sports stainless v-band housing. I am currently fiddling around with position of the turbo at the moment and just have a quick question to anyone out there thats removed headers. Does anyone know the inside diameter of the exhaust ports? As my 86 is on order and my current donor car is being daily driven i cant remove the stock headers to measure it up. Will be releasing a few teaser pics in the next few days depending on how long i can borrow my donor car for. Thanks Kal
post whore extraordinaire
Drives: 2013 Asphalt Grey FR-S 2003 Evo 8
Kal, hit Jason up from nameless performance. He would probably answer in a PM.
Mad Sciontist
Drives: gt86
I already have, Im thinking of just going with 1.5" sch10.
How far away are you mounting the turbo? What are your end goals, max power, or maximum useable range?
Mad Sciontist
Drives: gt86
At the moment I am waiting for some cnc flanges, turbo will hopefully be mounted by next week. At this stage it will be running 7psi (standard 7psi spring in the turbo smart 40mm waste gate). Eventually once cp finishes their low comp pistons and haltech finishes their PNP ecu I hope to be running around 350-450hp.
It's actually the first horizontally opposed engine I've ever stuck a turbo on so it's a bi of a learning curve for me. Kal
#6 | |
Flash the factory computer! |
| The Following User Says Thank You to Visconti For This Useful Post: | r0ma (07-22-2012) |
Mad Sciontist
Drives: gt86
That is definitely an option but I'm going to see what haltech comes out with first. They have been good to me since I bought my first e11 off them and will continue to use them as much as I can.
Kal.
Drives: JZA70 Supra, Lancer Evo 5, 86 GTS
Eagerly awaiting some pics!
#9 | |
Drives: 2jz
however give Solaris a try. its Uk based |
#10 |
Syvecs would be the best option if you were to go standalone
#11 |
Drives: 2jz
#12 |
#13 |
Drives: 2006 Subaru Liberty EZ30 S/charged
Something commonly used on a Global scale for Subaru cars is the Vipec V44
#14 |
It sounds like you are after useable power?
So I would utilize small to medium size equal length primaries (4 into 1 with possibly one step to increase velocity to the snail) with a proper merge collector, and then mount the turbo 4 to 6 inches after the collector on the flange, looks like you will be running an oil pump also. |
| Security system: BRZ vs. FR-S | Sport-Tech | CANADA | 16 | 05-30-2012 01:02 AM |
| Oil System? | swift996 | BRZ First-Gen (2012+) — General Topics | 5 | 04-13-2012 09:44 PM |
| BRZ Navigation System | Guaruja | BRZ First-Gen (2012+) — General Topics | 15 | 04-13-2012 08:52 AM |
| Using Subarus other turbo Boxers as an idea, how much HP could a turbo BRZ/FR-S have? | HitTheGas | BRZ First-Gen (2012+) — General Topics | 12 | 02-21-2012 01:24 PM |
| Geneva Preview: Techart to debut 911 Turbo, Turbo S | vh_supra26 | Other Vehicles & General Automotive Discussions | 1 | 02-22-2010 06:20 PM |
