Old 04-14-2016, 09:31 PM   #1
adjusts
adjusts's Avatar
Drives: 86
15mm 5x100 to 5x114.3 Conversion Spacer Question
so i'm about to receive some wheels in 5x114.3 bolt pattern (i am not looking to switch wheels). The problem is, our cars (FRS) comes with a 5x100 bolt pattern. I was thinking about running a 15mm 5x100 to 5x114.3 conversion spacer, but I am unsure if i will need to shave down my stock studs. I know that volk te37's come with holes in the back of the wheel to accomodate studs, but I am still unsure. Anyone run any TE37's here using a 15mm spacer? Not sure project kic's 11mm spacer will be enough, so im doing 15mm just in case. I wont go any higher, nor am I looking to replace my stock studs.
If I do happen to have to cut my stock studs to use the adapters, will i still be able to take out the adapters and remount my oem wheels (5x100) if winter comes?
Also, while I'm here, anyone have any suggestions for locking lug nuts I should or can use with project kic's 15mm 5x100 to 5x114.3 conversion spacer?
adjusts is offline   Reply With Quote
Old 04-14-2016, 10:50 PM   #2
lupindub
Drives: Scion FR-S
Originally Posted by adjusts View Post
So I'm about to pull the trigger on some TE37's in 17x9 +22 offset. The problem is, our cars (FRS) comes with a 5x100 bolt pattern. I was thinking about running a 15mm 5x100 to 5x114.3 conversion spacer, but I am unsure if i will need to shave down my stock studs. I know that volk te37's come with holes in the back of the wheel to accomodate studs, but I am still unsure. Anyone run any TE37's here using a 15mm spacer? Not sure project kic's 11mm spacer will be enough, so im doing 15mm just in case. I wont go any higher, nor am I looking to replace my stock studs.
The stock stud's on our car extends 24mm. This means that if the pocket on your wheel's are not 9-10mm deep, you will have to shave your studs.
Also the spacer has nothing to do with you being able or un-able to use locking lug nut's. Just depends on your wheel's.
lupindub is offline   Reply With Quote
Old 04-14-2016, 10:58 PM   #3
adjusts
adjusts's Avatar
Drives: 86
if i shaved my studs, will i still be able to mount oem wheels using the shaved studs? or will they not be long enough? might be looking at shaving around 5-7mm off the stud.
Old 04-14-2016, 11:03 PM   #4
lupindub
Drives: Scion FR-S
You won't be able to go back. The most amount you can SAFELY shave off is 3mm. Obviously you can shave off more but at your own risk. This goes with non-bolt on spacer's as well. 3mm should be the maximum amount of spacing you should do if it is not a bolt on spacer.
Old 04-15-2016, 10:54 PM   #5
dobbrz
Drives: RB v1 FRS
unless you replace all your studs each time you want to go back to 5x100...lol
PROPΔGΔNDΔ
DRIVEN TO INFLUENCE
instagram: @andrewdobbie93
dobbrz is offline   Reply With Quote
Old 04-17-2016, 01:37 AM   #6
dito
Drives: SWP BRZ
i threw on a 15mm spacer and shaved off the stud bc my wheel didnt had pocket big enough for the stud. had to replace stud when i got new wheels with better offset
dito is offline   Reply With Quote
Old 12-14-2016, 09:20 PM   #7
jordonallison
jordonallison's Avatar
did you have to shave your studs though?!?!?! huh?!?! did you?!?!
IG @jordonallison
jordonallison is offline   Reply With Quote
Old 12-15-2016, 12:50 AM   #8
adjusts
adjusts's Avatar
Drives: 86
ya!!1!11!!1!11!1one
Old 12-15-2016, 01:10 PM   #9
8R6
8R6's Avatar
Drives: FRS
easier and less headache to just get a set of 5x114.3 winter wheels instead
8R6 is offline   Reply With Quote
BNIB Project Kics Conversion 11mm spacer 5x100 to 5x114.3 Pekingduck Wheels and Tires 6 02-11-2016 12:33 AM
FS: ISC 15mm black 5x100 to 5x114.3 conversion spacers Road Pirate Wheels and Tires 3 09-11-2015 09:43 AM
Project Kics 11mm or 15mm P.C.D. Conversion Spacer - 5x100 to 5x114.3 (12x1.25mm) Evasive Motorsports Wheels and Tires 31 06-13-2015 08:09 PM
CUSTOM Wheel spacers/adapters 5x100 & 5x114 conversion (15mm / 20mm / 25mm) JonMotoring Wheels and Tires 102 04-30-2015 08:22 PM
Project Kics 10mm 5x100 to 5x114.3 Conversion Spacer Hubcentric deedz Wheels and Tires 12 05-22-2013 04:18 AM
