Old 04-05-2016, 07:11 PM   #1
radroach
Drives: car
How to remove change tray?
Guys I've had trouble removing the change tray that's below the HVAC controls, with the normal style tray (limited BRZ). I was trying to remove it so I could get to a couple screws inside there.
The instructions to remove the tray were to reach under the passenger wide with my hand and use my fingers to force it out. Unfortunately, this ended up with me cutting my finger against something metal. And while my finger's aren't stubby (I assure you Donald) they probably aren't long enough to easily pop out the tray. I tried pressing against it and got some force on it, but not enough.
Does anybody have any tips for getting the tray off? What direction should I be pressing it from to pop it out?
Old 04-05-2016, 07:26 PM   #2
Irace86
Drives: BRZ + Ducati M796
Pop out the plast piece on the passenger side. Just pull and it will unclip. Then reach until you feel the back of the usb box. Push it out. Disconect. Then you should be able to tug out the tray.
Irace86 is offline   Reply With Quote
Old 04-05-2016, 08:09 PM   #3
sdemo
sdemo's Avatar
Drives: '13 SWP ZC6 R
It takes a surprising amount of effort. Keep at it, you won't break it... push out from behind.
sdemo is offline   Reply With Quote
Old 04-06-2016, 12:58 AM   #4
86kahl
86kahl's Avatar
Drives: whiteout, dark tint
It's just a huge pain TBH. I just kept pulling and pulling till it finally unclipped. Most frustrating part of changing the clutch imo
86kahl is offline   Reply With Quote
The Following User Says Thank You to 86kahl For This Useful Post:
radroach (04-06-2016)
Old 04-06-2016, 02:02 PM   #5
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
you have to remove that tray to change the clutch
The Following User Says Thank You to NyC Zn6 For This Useful Post:
go_a_way1 (04-06-2016)
Old 04-06-2016, 02:11 PM   #6
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
That tray is a little bitch. I have taken mine off 50+ times by now I bet. Best way to do it I find is remove the lower trim bit on the passenger side so you can reach in behind (its tight) and pop the usb thing out. Unplug that then stick your fingers in the hole and give it a good pull
Old 04-06-2016, 02:15 PM   #7
mixtape
Posts in the nude
mixtape's Avatar
Drives: 2016 WRB BRZ
*Michael Scott hears this down the hall, runs in to the room sweating and panicked*
"THAT'S WHAT SHE SAID"
2016 Subaru BRZ - World Rally Blue [Build Thread]
Instagram: @mixtography | My Automotive Photography
"Lesbian trees have no wood." - Scoobs McGee
mixtape is offline   Reply With Quote
The Following 2 Users Say Thank You to mixtape For This Useful Post:
go_a_way1 (04-06-2016), Harvie1031 (04-07-2016)
FI Hood insulation: To remove or not to remove bryan767 Forced Induction 8 08-15-2015 04:51 AM
Can someone tell me how to remove BRZ Limited start button/tray/USB MikeM7 Cosmetic Modification (Interior/Exterior/Lighting) 3 02-22-2015 07:43 PM
Oil Change Interval Change (Subaru recommended) Flow Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 34 09-10-2014 07:27 PM
FS: VIP Tray frs4mark Interior Parts (Incl. Lighting) 0 04-20-2014 03:19 PM
will polishing your car to remove swirls remove opti-coat? bacon_cheese_beer Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 10-25-2012 10:41 PM
