Old 04-04-2016, 12:48 PM   #1
handsomegirl
Drives: Toyota GT86 2015 Black Aero Kit.
Headlight turns on unlock MOD
Hi,
With the keyless version of the Toyota 86/FRS, when you walk up close to the car, the interior dome light will automatically turn on whether you unlock the car or not. Is it possible to somehow make it so when I walk up to the vehicle, when the dome light turns on, have the headlight also turn on. Just like the european cars.
handsomegirl is offline   Reply With Quote
Old 04-04-2016, 01:56 PM   #2
elBarto
elBarto's Avatar
Drives: Toyota GT86
My EUDM GT86 just lights up the dome light. Even when I unlock it, it just lights up the dome light. I don't know if there's a "coming home function" on the twins. Maybe with the Tap-Turn module?
send from the coffeemaker
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
Old 04-05-2016, 08:34 AM   #3
Ashikabi
Ashikabi's Avatar
Originally Posted by handsomegirl View Post
Hi,
You "could"rewire it but it's not gonna be fun. I advise against it unless you really really really really want it
Old 04-15-2016, 11:40 AM   #4
itsAlex
itsAlex's Avatar
Drives: 2016 4Runner / 2016 FR-S
You could use a micro controller (like Arduino) to make it happen. It's actually really simple:
When you turn the headlights on manually, what you're doing is grounding a specific wire. When that specific wire is grounded, that tells the ECU to turn on the headlights.
All you'd have to do is tap this specific wire and connect the tapped wire to an output on a micro controller. Then you'd program the controller to ground the wire, thus turning on the headlights.
You can program the controller to receive a series of signals in order to do this, such as a signal to let the controller know that the ignition is not on, and another signal to let the controller know that the smart key is near by.
The only problem I see is finding a power source that will turn on the controller when the smart key is nearby. You don't want the micro controller to be on 24/7, even if its current draw is minimal.
I pay more per month for insurance than I pay for the FRS.
itsAlex is offline   Reply With Quote
Old 04-15-2016, 02:17 PM   #5
yefoo
Drives: 2016 BRZ CWP
My '16 BRZ limited keeps the lights on when I park the car on auto light mode. Never noticed the lights turning on when I unlock/walk up to the car though. Then again I never really tested it. Kinda weird that it would have the coming home feature but not the leaving home feature.
I also have the tapturn module and that does have both coming home and leaving home feature but it only turns on the signal lights so I get a nice amber illumination instead of full blast headlights.
yefoo is offline   Reply With Quote
Door Unlock Issue TONYpepperon1 Issues | Warranty | Recalls / TSB 20 01-05-2018 07:06 PM
HID Headlight turns off during spirited driving tinma Cosmetic Modification (Interior/Exterior/Lighting) 14 11-19-2015 10:23 AM
keyless passenger unlock danman2_2999 BRZ First-Gen (2012+) — General Topics 4 06-08-2014 08:05 PM
Blackberry unlock pronky Other Vehicles & General Automotive Discussions 3 10-30-2010 07:39 PM
