Drives: 2013 Fr-s
FA500, Rs*r , RCE coilovers .
What would be best for just daily driving and once in a while. Hard on corners? I'm on TRD but I was just gonna go with swift spec r but a few people mention I will need to change the shock , so I decided might as well go coilovers. I'm still new to suspensions. So any feedback will help. My wheels came in so I'm thinking of getting sticky tires. any recommendations? My budget is at 2k. but I love saving money as well lol. my lower control arm. I'll be going with Spl or something like that. don't want to understeer much. So advice there will be appreciated.
P.s. any frs meet in North cali? Sent from my SM-N920T using Tapatalk |
Junior
Drives: a car
I would rec RS*R and RCE vs FA's. Nothing against FA, good quality coilover, but if budget is 2k, the closest you can get the better.
The other route (which is what im about to explain) would be to do the swift springs and B8 Bilstein shocks. Cheapest, and probably your best bet since most dont need adjustment, or for those who dont much care for ride height adjustability.
| The Following User Says Thank You to cdrazic93 For This Useful Post: | Calum (04-03-2016) |
#3 | |
Drives: 2013 Fr-s
Drives: Satin White BRZ Limited
I really like my Tein Flex Z. Great daily driving coilover and handle better than stock (if set up correctly with good alignment). I have had them for 5 months now. They have given me 0 issues. I really cannot believe the quality of these for the price.
That Guy
Drives: 2013 asphalt FRS MT
RCE yellows and Bilstien B6 would be a better choice than all of those. No ****ing around just install, align, and go. You get a tasteful drop that doesn't ruin the handling, dampers that will work well with the springs, springs that work well with a wide range or tires, and lots of suspension travel for a comfortable ride and good handling. Oh, and it would cost less, if nothing else because you don't have to pay for corner balancing (3-5 hrs of labour), and adjustable end links to prevent preloading your sway bars.
| The Following User Says Thank You to Calum For This Useful Post: | cdrazic93 (04-03-2016) |
#6 | |
Drives: 2013 Fr-s
#7 | |
That Guy
As for camber plates, for your use, I don't see the need. They certainly have advantages, but the ride, NVH, and maintenance, just don't seem worth it to me. At the very least, wait and see. Installing camber plates on this car is pretty straight forward so it wouldn't take much to add them later if the need arises. Suspension mods are very subjective so it's hard to say what your driving style, roads, personal taste, etc will demand. But for a DD I'd recommend either the stock mounts, or getting group n mounts, and running bolts to dial in some more camber. |
#8 | |
Drives: 2013 Fr-s
#9 | |
That Guy
I think we skipped a step here. Why do you want to 'upgrade'? The factory suspension is pretty competent. Unless you're seeing an issue you probably shouldn't be doing anything. And, about your driving style, that wasn't a dig, or even a question of experience level. Different drivers within the same skill level will prefer different setups, there is no one size fits all for suspension tuning. Even the idea of neutral can be different from one person to another. |
#10 | |
Time Traveller
Coming from a person that has owned RS-R Sports-i's on his DD for the past 2 years, I will say that they ride much better on California's rough roads and raised the performance envelope of my car considerably over aftermarket springs + stock shocks (which I have also ran). Handling is far from "ruined". They were easy to setup and don't require camber plates to get -1.0 to - 2.75 camber on the front (-1.5 out of the box, and add camber bolts to get to that max number). There are a few notable forum members who run Racecomp Tarmac 0 and 2's that could also provide first hand feedback to the OP (notably @ATL BRZ ). Your advice is nice to see, but I think you jumped the gun on this one. |
#11 | |
Drives: 2013 Fr-s
#12 | |
Drives: 2013 Fr-s
#13 | |
Drives: 2013 Fr-s
#14 | |
That Guy
I'm running T0's with group n mounts. My advice was based on a guy looking to make his DD, that mostly see typical highway driving with the occasional fun on ramp, handle a little better/more forgiving. The parts I recommended should do that without changing the ride much, and without requiring a lot of extra expenses. If OP is insistent on coilovers, then the advice will change, and as I haven't had the chance to compare many different coilovers, I'll let others answer that question. But I stand by my advice, adjustable suspension isn't much of a benefit for a daily driver. Of course it could improve handling, but the cost:benefit ratio doesn't seem to fit, to me. Any damper with adjustable perches should be corner balanced. Sure, you could set them by measure them perch height, and that would likely work ok. But if that's all you're doing, why pay the extra money for the adjustability? I was referring to the drop ruining the handling, not the coilovers. I also didn't say coilovers would require camber plates. Edit, I'm not sure if you're talking about the Tarmac springs or the Tarmac 0's, so some of that might not be applicable. Last edited by Calum; 04-03-2016 at 09:03 PM. |
| Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! | No Limit Motorsport | Brakes, Suspension, Chassis | 204 | 05-26-2017 12:09 PM |
| DSG Edition FA500's | go_a_way1 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 47 | 04-20-2016 06:15 PM |
| FA500 V5 help | sosick | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 03-23-2016 01:48 PM |
| FA500 vs Stance SS vs BC - most front camber? | manualmotive | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 04-09-2015 02:08 PM |
| FRSport Special: Fortune Auto FA500-BRZ 500 Series Coilovers FR-S BRZ | FRSport.com | Brakes, Suspension, Chassis | 0 | 12-09-2014 12:13 PM |
