Old 03-29-2015, 08:25 PM   #1
manualmotive
manualmotive's Avatar
Drives: '14 BRZ Todoroki/OriginLabo
FA500 vs Stance SS vs BC - most front camber?
So I'm currently just waiting for one of the following coilovers to be posted on a used parts forum: Fortune Auto 500, Stance SS, or BC (:/). Will all these coils have the same amount of max front camber adjustability with their top mount camber plates? Or will some offer more than others?
I'm already running whiteline camber bolts in the front but only getting -1.2 camber in the front. I'm looking to get at least -3 degrees out of the front when the coils go on. Will all of the coil options listed by fine for that or will I need additional mods?
And what about camber correction on the rear? I only want -1 to -2 degrees in the rear and I'm already getting over 2 of natural camber on Sportline springs (-1.5in). Most likely getting PBM RLCA's to deal with this though.
Looking to be dropped 2.5 inches all around, give or take a half inch.
Sorry for the weak ass thread but nothing helpful was coming up in the searches.
manualmotive is offline   Reply With Quote
Old 03-29-2015, 08:35 PM   #2
murdoc
Sometimes I'm wrong.
murdoc's Avatar
Drives: '13 FR-S/'96 240SX
I think that stance and maybe fortune have slotted upper holes on the lower mount, which allows for a bit more camber if you have the tire clearance. That way you just bolt it up with max camber on the lower mount before you align it.
I've only had their 240sx coilovers though, so you'll have to check with someone here who has them.
murdoc is offline   Reply With Quote
Old 04-06-2015, 12:18 PM   #3
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
What are you going for? FA500s won't give you the drop you are looking for if you want "slammed". They give a lot of camber, but I haven't maxed mine yet. Rears are maxed(lowest) btw:
DustinS is offline   Reply With Quote
Old 04-09-2015, 03:24 AM   #4
manualmotive
Thanks ^ I'm assuming you're on stock rear LCA's? With Stance or PBM it lowers the rear another inch.
PS: I'm also planning on getting federal 595's and filling in the lettering lol. Good taste
EDIT: How close are you to max low in the front?
Old 04-09-2015, 09:45 AM   #5
DustinS
DustinS's Avatar
I am pretty close. I think I am going to drop it as low as I can and raise it from there. I'll get pictures.
Old 04-09-2015, 02:08 PM   #6
manualmotive
Interested to see pics. Also if you want to sell your coils I'll pick them up hahah. Think I'm gonna go with the fortunes and pbm rcla's. I've read with that setup max low is about 3" all around if I really felt like making it undriveable
EDIT: Wheel/tire specs?
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! Corner3garage Southern California 188 04-24-2015 01:10 PM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 03:40 PM
