Old 04-01-2016, 03:30 PM   #1
Dimitris
Drives: Toyota gt86
Jdl el catted ultra quiet over front pipe 2.5 Perrin resonated
Hi I am new to the forum so excuse me if I am of topic and also I am sorry for my English you see I am from Greece.
My question is this what do you think of this setup I am thinking of a jdl el catted header jdl ultra quiet over front pipe and 2.5 Perrin resonated cat back exhaust does anyone have this setup what do you think in terms of loudness an power gains. I want a quiet exhaust set up for when I am cruising and when I step my foot on the gas above 4000 or 5000 rpm to scream like its a monster not a stupid loud sound but a deep sound like a scream.
If someone has this set up I want to hear a clip if possible.
Dimitris is offline   Reply With Quote
The Following 2 Users Say Thank You to Dimitris For This Useful Post:
buruguduy (06-08-2016), Chad86 (06-08-2016)
Old 04-01-2016, 03:46 PM   #2
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
Enjoy:
http://www.ft86club.com/forums/showthread.php?t=103814
"Practice makes better. Only Senna is perfect." - CSG Mike
LOLS2K is offline   Reply With Quote
The Following User Says Thank You to LOLS2K For This Useful Post:
go_a_way1 (04-01-2016)
Old 04-01-2016, 04:27 PM   #3
kch
Senior Misanthrope
kch's Avatar
I don't know of many people using the EL catted header from JDL. But I can confirm that the UQFP + Perrin 2.5 resonated will sound nice and deep. It will probably sound like mine, but a little quieter, and without the rumbles:
[ame="https://www.youtube.com/watch?v=VnEYvkiW5k0"]BRZ w/ JDL UEL & Perrin resonated drive by - YouTube[/ame]
The Following User Says Thank You to kch For This Useful Post:
Chad86 (06-07-2016)
Old 04-01-2016, 04:55 PM   #4
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
You can't go wrong with that setup. Will keep the car nice and quiet and will produce a nice, non-raspy tone because all of those exhaust components are good quality. I say go for it!
Instagram: trevor.parque
Old 04-01-2016, 05:22 PM   #5
Dimitris
Drives: Toyota gt86
What do you think about drone will it produce any because I really don't want that. Also about power gains will it be about 10 whp or not?
Old 04-01-2016, 05:24 PM   #6
MisterSheep
Killed Scion
Yeah. If you get it tuned you should get about that much and you will not get much to any drone with that setup.
Old 04-01-2016, 10:22 PM   #7
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
@DimitrisThat is my set-up, except that I have a normal catted front pipe, not the JDL Ultra Quiet front pipe. Sound is amazing. Volume is low when behaving and makes some good noise when I'm not behaving. No real drone, you just know the exhaust is there at 80+mph.
Lots of sound clips: www.youtube.com/thebatstig
BatStig is offline   Reply With Quote
The Following 2 Users Say Thank You to BatStig For This Useful Post:
Chad86 (06-08-2016), freerunner (06-09-2016)
Old 04-02-2016, 03:45 AM   #8
Dimitris
Drives: Toyota gt86
thank you for your help and answers the question now is can i change something in this setup to make it better in terms of sound and power for sound less in low rmp range and more in high rmp range and abot power i really dont care about mid range i want the high end power that is why i chose the el header but also i dont like the rumble.
Old 04-03-2016, 05:47 PM   #9
JGalp
Drives: 2015 CWP BRZ Limited
does just the header + tune eliminate that horrible torque dip?
JGalp is offline   Reply With Quote
Old 04-04-2016, 01:42 AM   #10
Rifle
EX-86 Supercharged God
Rifle's Avatar
Drives: '16 Series.HyperBlue BRZ
Just to throw my .02 in..
I'm running Tomei EL, PLM OP, HKS Dual Resonated Front Pipe, and Perrin 2.5 Resonated. To reiterate, I'm FULL CATLESS, but I do have 2 extra resonators. That being said, I have absolute 0 drone with the Perrin, as opposed to the Invidia N1 that I had. I'm sure you're trying to be carb compliant with the catted header, but do yourself a favor, get a catless header, and keep a hi-flow catted front pipe. Most places for inspection won't even bother to remove the under panel shrouds to check for 'tampering', you'll want a tune regardless, because anything outside of OEM MAY produce codes. Good luck!
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ
Rifle is offline   Reply With Quote
The Following 2 Users Say Thank You to Rifle For This Useful Post:
Chad86 (06-07-2016), MisterSheep (04-04-2016)
Old 04-04-2016, 12:48 PM   #11
kch
Senior Misanthrope
kch's Avatar
Almost entirely. This is with a full exhaust and E85 tune, but just a header+tune will give you a similar torque curve.
Old 04-04-2016, 02:14 PM   #12
BatStig
Some say.....
BatStig's Avatar
@JGalp Yup.
The Following User Says Thank You to BatStig For This Useful Post:
TofuJoe (10-02-2016)
Old 04-04-2016, 02:39 PM   #13
MisterSheep
Killed Scion
What exhaust setup are you running and what does a stock car make on that dyno?
Old 04-04-2016, 03:06 PM   #14
kch
Senior Misanthrope
kch's Avatar
Stock car does between 165-172 on that dyno. My pulls were on a 96*F afternoon, so I could probably go higher on a cooler day.
Exhaust:
JDL catless UEL
JDL 2.5" OP
JDL 2.5" UQFP (high flow cat and resonator)
Perrin 2.5" resonated catback
Other factors that probably played a role:
apexi drop-in filter
OFT E85 tune
I'm going to make some more pulls soon now that I'm on ECUtek to compare with OFT.
The Following 3 Users Say Thank You to kch For This Useful Post:
Chad86 (06-07-2016), DocWalt (06-08-2016), MisterSheep (04-04-2016)
Catted, resonated, or catless front pipe with Perrin Exhaust? brzbrad Engine, Exhaust, Transmission 19 07-03-2016 11:44 PM
WTB 2.5inch JDL Ultra quiet front pipe RobertPaulson Want-To-Buy Requests 1 05-14-2015 04:41 PM
WTB: JDL Ultra Quiet Front Pipe akahenry Want-To-Buy Requests 0 02-25-2015 10:57 PM
FS in NY 10803: Perrin 2.5" resonated + P&L catted front pipe dp1 Engine, Exhaust, Bolt-Ons 6 08-15-2014 01:35 PM
WTB: Perrin Over Pipe + Catted Front Pipe + Cat Back (Resonated) coolaron Engine, Exhaust, Bolt-Ons 0 07-13-2013 03:37 PM
